Turbo installed.... now it won't even crank.
Old Dec 9, 2006
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
The only things electrical related I touched were relocating my battery's ground wire to the unibody off the clutch hydro line bracket, unplugged this sensor on the top of the trans (to remove the aforementioned bracket) then plugged it back in, unplugged my O2 sensors to install the new downpipe then plugged back in, and plugged in Dezod's E-Manage harness.
Now when I turn the key, my dash lights come on (CEL, brake, Oil, Maint. Req'd, etc.) but not my fuel pump, radio or A/C blower. Then when I crank the key to start, there is no clicking, the lights don't flicker and it won't crank. I checked my battery - it's got a full charge. I also check my starter and it works too.
Now I do hear a soft clicking noise from the glovebox area. Is that coming from one of those two relays or something?
Anyway.. I've had my car sitting there trying to get it to start for like 4 days now and I REALLY need to get it back. It has been down for this install for like 3 weeks and I really need it back.
Thanks in advance.
Old Dec 9, 2006
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
sorry to hear about that logic, but have you checked your fuses?? i really dont know much but just a suggestion.
Old Dec 9, 2006
dezod's Avatar
7thgen Power Maker
Check your fuses.
Old Dec 9, 2006
TheSmuggler's Avatar
Yup, I'll throw down it's the fuses
Old Dec 9, 2006
All my fuses are OK. All the relays in the engine bay are OK. The 3 relays under the hood I can't get out to save my life so I can't check them.
The other question I've come up with is when I try and jump the low amp side of the starter solenoid, it won't turn the starter over. Is there some sort of interrupt?
Old Dec 9, 2006
Mike04Civic's Avatar
Mike04Civic is an unknown quantity at this point
tried moving your ground back to where it was?
Old Dec 9, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
One of the 2 relays in the glove box is the fuel pump relay (the one on the right I think). May want to make sure its properly seated, especially if you were wrestling with the ECU wires behind it, and say you cant tell if the pump is on or not.
Old Dec 9, 2006
I check both of those two and I can't get them out - but they are securely seated. The 3 relays under the driverside are the other ones I can't remove to check.
and...
The bracket the ground was connected to held my clutch line to the transmission. That bracket had to be removed in order to fit my intercooler piping through there. I tried grounding to my trans mount as well as a hole in the sheetmetal. I stripped the paint off with a screwdriver.
Old Dec 9, 2006
just a thought
Old Dec 9, 2006
well if you hear clicking, the relay is bad, regardless of whether its seated properly
Old Dec 23, 2006
Burnin_ruberv8's Avatar
Burnin_ruberv8 is an unknown quantity at this point
How your car??? did you fix it?? and what was it???
I'm intersted to know what caused this so turbo'ers don't fall in the same mistake
Old Dec 23, 2006
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
check all your grounds, because what you are describing is exactly what happened to me. I took out my battery to clean my CAI and when I put it all back in my car wouldn't start. My dash lights came on and I also heard clicking from the glove box. Got it towed to honda and it took them 3 days to find out and 200dollars later that a ground wire was loose.
Old Dec 23, 2006
drew22mader's Avatar
There is gl@ss in my @SS...
guys, he's already fixed that.
Old Dec 23, 2006
affixrider's Avatar
affixrider will become famous soon enough
hey if you are still having the problem, thwn i would check all of the sensors. after that the main problem would be the ground. the fuses should be the last thing if its still trying to click.
Old Dec 23, 2006
omg, do u freakin read? gzzz people, I JUST SAID HE FIXED THE PROBLEM GD
Old Dec 23, 2006
^STFU IMA GROWN *** MAN I DO WHAT I WANT
Old Dec 23, 2006
Yeah we already know he fixed it... but we were wondering what caused it so we can learn from it...
Old Dec 23, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Don't let your idiot friends help you make it worse.
Old Dec 24, 2006
lol no prob
Old Dec 24, 2006
I'm doing a turbo install the first time on ma friends car... so if anything get loose i'm the one to point at lool
Old Dec 25, 2006
LOL Drew to my rescue. Yes, I fixed the problem. Here is a link to the thread describing the ordeal.
https://www.civicforums.com/forums/4...ing-again.html
justcruzin125
Aug 11, 2015 09:09 PM
jnissen
Aug 9, 2015 05:34 PM
Civic65
Jul 19, 2015 10:13 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
