Emanage/ Support Tool Problem
Old Nov 26, 2006
sb143hd's Avatar
sb143hd is an unknown quantity at this point
I just installed my e-amange I had all the PNP harnesses so it made things easy. However when I went to hook up the cable included with the support tool, it wont hook up to my computer. Did any of you have this problem? I figured it was my computer and it's lack of the correct port, I took my computer to a shop and they said I need an older laptop that has a serial port, they didn't know if there is an adapter.... is there? Also once in, my e-manage kept flassing 1...4 so 14 which is VETC SIGNAL INPUT ERROR.... problem is I dont have VETC, it's set on 4-8-c. I bought my emanage used and I was wondering do I need to unjump jp3, jp6, jp5, jp2, jp1, jp7, jp4???
Old Nov 26, 2006
dezod's Avatar
7thgen Power Maker
Check your jumpers, those can assure tons of problems.
The rotary settings for the D17....there have been 2 that have been documented to work: 4-8-C and 4-8-E. It is trial and error at best. No rhyme or reason why one works on something other than another.
You can use a USB to serial adapter, but the e-manage is fussy on which one it will speak to. I like the Iogear one and have never had a problem with it. I have had problems with the Belkin edition.
Old Nov 26, 2006
tfnaaf's Avatar
BLDNPSI Mod
see my other reply to your ????
Old Nov 26, 2006
sb143hd's Avatar
Just ordered my adapter! Thanks for all the info guys!
Old Nov 26, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
i've used the one from radioshack. it worked well for me.
Old Nov 26, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
i am using the belking one, no problems yet!
GolNat
Suspension DIY
May 12, 2022 06:49 AM
CarStuff
Dec 6, 2020 12:52 PM
usajags84
15
Aug 19, 2015 03:12 AM
beveragemp
May 25, 2015 07:11 PM
oneheadlight
Apr 29, 2015 11:30 PM
