Turns but wont start!
Old Nov 6, 2006
  #31
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
piston #1 is at power stroke
Old Nov 7, 2006
  #32
ryangt's Avatar
ryangt is an unknown quantity at this point
if piston number 1 is at tdc and the crank is at tdc and the cam gears are at tdc then your fine there. Hows the tension on the belt?? is it tight how it should be or loose like the sleeve of a wizard.
Old Nov 10, 2006
  #33
timbo's Avatar
timbo is an unknown quantity at this point
I would assume you had the head milled or checked to make sure it isnt warped. If you have it at tdc of #1 and the cam marks aligned all sensors plugged in spark and fuel it will start. Did you install new plugs? Becuase if it was overheating the plugs could be fouled. or even if you did check them to see if cylinders are free of unburnt fuel.
Old Nov 11, 2006
  #34
BoostedVik's Avatar
i did not check to see if the head was warped but the spark plugs are in GOOD condition so i am using them.... like i said before i have the cam and crank on tdc i think its just time before i get the timing right .. i am doing all this on sunday if i dont get it right i am taking it to my friend, he has a shop, he can **** with that stupid *** honda, i ****ing hate honda
Old Nov 11, 2006
  #35
ryangt's Avatar
dont hate the car becuase you didnt know what you were doing.
Did you replace the gasket because the car overheated?? Thats why the head would be warped, i got the impression you were replacing it just because you wanted to.
From everything you have going on, its a timing issue. Take the time and do it right AGAIN, make sure its right.
Old Nov 11, 2006
  #36
puidokas's Avatar
puidokas is an unknown quantity at this point
Yea sometimes i feel like that too, just relax man youll figure it out.
Old Nov 11, 2006
  #37
ryangt's Avatar
walk away from it for a day or so, it will give your brain time to say WTF OH THATS WHAT I MISSED!!! youll get it, just dont quit on it, its a learning experiance if anything.
Old Nov 12, 2006
  #38
BoostedVik's Avatar
hey listen dudde, just cuz i am stuck at a point where my car is not running doesnt mean i dont know what i am doing.... so i dont need u saying **** like that, u have been helpful +1 rep for you but please keep negative comments to ur self!
Old Nov 19, 2006
  #39
circularlogic's Avatar
circularlogic is an unknown quantity at this point
Did you ever get it fixed, I am having the same problem and will be rechecking everything today with my mechanic. It almost acts like it is not getting fuel, but before I replaced everything, the car ran great. I just had to replace the water pump and now this. I would like to know if you ever got your car fixed and what was the problem.
Old Nov 26, 2006
  #40
BoostedVik's Avatar
last thing i checked was the compression and i had none, so i took off the head back off and found out that i bent the valves (somehow, i spund the crank before i started the car) anyways i replaced the valves and now i am back in the games, hopefully i will tune it on monday!!!! hell yes
Old Nov 26, 2006
  #41
andyman97's Avatar
Turbo Guru
^You do know what causes bent valves, right? Having the timing belt off by a few teeth.....
Old Nov 26, 2006
  #42
TRIZ's Avatar
hmmm, I could say something funny but I guess i'm supposed to keep thoes "negative" comments to myself.. hmm! All in fun man.
At least your running again- Get that sucker tuned and start hauling *** again!!
Old Nov 26, 2006
  #43
BoostedVik's Avatar
yup....
Old Nov 26, 2006
  #44
BoostedVik's Avatar
you can say something funny i dont care, i make fun of my self all the time!
Old Nov 26, 2006
  #45
kornsined's Avatar
Ouch. That was a waste of money. Too bad, but you got it back up and running.
Old Nov 27, 2006
  #46
ryangt's Avatar
shoulda just taken it to honda, woulda been faster and youd of had the accountability factor if they screwed up. Tho they probably would have blamed you for the bent valves haha
Old Nov 27, 2006
  #47
ryangt's Avatar
p.s. How much were your replacement valves? Whered you get them, and did it take out all your valves or just a few?
Old Nov 28, 2006
  #48
BoostedVik's Avatar
total parts was $250 valves/ all gaskets, ect.... replaced all of them!
Old Dec 8, 2006
  #49
Mike04Civic's Avatar
Mike04Civic is an unknown quantity at this point
oops - i guess checking compression might have caught that...
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
ayoitzjulesdx98
May 13, 2015 08:31 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
