RSX-S shifter issues
Old Aug 29, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
anyone else have this problem? ...
whenever I go into reverse, my shifter stick hits the center console where the boot is. Not quite sure how to explain it, but I'm sure u can figure it out.
I'm wondering if anyone has a k20a2 swap with the stock civic shifter. I know I won't have the same problem the stock shifter, but at the same time, I'm not sure if it will fit [because one guy said it wouldn't ... so I took his word for it].
on our civic shifters, the stick is bent to the left ... on the rsx, it's bent to the right ... so it hits the center console while going into reverse ...
Old Aug 29, 2006
claudeboi's Avatar
im a psychopath...what are you looking at?
claudeboi is an unknown quantity at this point
i would luv to help you man....but i dont have a k20 swap
bump for this guy, i would like to knw also---
Old Aug 29, 2006
eye_see_you's Avatar
let the devil out
are you talking base 5 speed or 6 speed my buddy club SS is bent to the left not the right in my rsx
Old Aug 29, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
I thought u could use our stock shifter if you just trim some plastic on the shifter assembly where reverse would be. That way it might fit with our stock trim piece.
Old Aug 31, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
well, u know. the title says RSX-S shifter, so I would assume that everybody knew that I was talking about 6-speeds ...
scansel: no idea ... that's why I was wondering if anyone knew. I've been using the 6-speed box from day one ...
Old Aug 31, 2006
scansel912's Avatar
I would try putting in our stock shifter and see if you can reach 6th. If not, try taking a dremel and trimming a section so you can reach it. Then see if it works with teh stock trim piece
Old Sep 1, 2006
HondaLuver's Avatar
Its a celebration bitches!
idk what your talking about, i never hit anything when i go in reverse...
Old Sep 2, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
i too am perfectly fine... never had any probelms... stick shifter... type s shifter.. and even with the DC short shifter adapter on there too and had no problems
Old Sep 4, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
I had the type S shifter, and it looked the same as my 7thgen shifter, so I just left the 7thgen in and have not had a single problem?? I also have the DC ss adaptor.
Old Sep 5, 2006
HondaLuver's Avatar
derik, do you have that type R center council?
Old Sep 5, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I have it, but I currently have an 02 center console on right now.
why, want it? ;P
Old Sep 5, 2006
HondaLuver's Avatar
no... doesn't fit
NeoMagus
Apr 20, 2005 12:39 PM
BIG
16
Feb 26, 2002 11:43 AM
sadboy916
Feb 24, 2002 10:42 AM
BIG
Feb 11, 2002 01:23 PM
CiViCPrAnInG2k1
Dec 6, 2001 12:14 PM
