k20 bored at 89 mm Darton sleeves
Old Aug 20, 2006
bluehonda1's Avatar
bluehonda1 is an unknown quantity at this point
hey guys, Just wanted to find out if anyone has bored their k20's at 89mm with darton sleeves if so, any idea of hp gain from before and after.
Old Aug 20, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
confused.
you want to bore cylinders, install sleeves, gain horsepower? i do believe that sleeving a block is just for cylinder strength not power gain (read below)
cylinder sleeving is used to increase the strength of the cylinder walls mainly for turbo applications. the stock walls arent very strong under boost and are limited to a certain ammount. sleeved block can handle much more pressure. some builders claim sleeved blocks capable of up to 30-35 psi.
Hp gain before and after would be nothing i meen, you bore the cylinder, insert sleeves, bore the sleeves to fit the pistons and put back together? how does that make power?
maybe i'm confused by the question, try again.
Old Aug 20, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
Originally Posted by XSRCivic
confused.
well.....i just learned something new today
Old Aug 21, 2006
bluehonda1's Avatar
your right dude. I knew that upgrading to a sleeve kit would give me more capability to hold more boost and make the cylinders walls stronger but i wasnt sure if there was any hp gains if done so. Thanks for the info.
Old Aug 22, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
well, when you bore the block you increase displacement which can potentially show a slight increase power if i am not mistaken.
Old Aug 22, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Theres so many variables like compression, fuel, cam, air to see whether you would gain power. But I would argue that since you have more displacement (assuming you are keeping stock stroke length) you will have more power assuming you aren't choking the engine with not enough cam or anything else that i said above.
Old Aug 23, 2006
HondaLuver's Avatar
Its a celebration bitches!
blah blah blah
Old Aug 23, 2006
fulltimeride's Avatar
fulltimeride is an unknown quantity at this point
when you bore something out to take a larger diameter piston you increase displacement2.0 to a 2.30, 1.7 to a 2.0. you can increase hp by using a wider piston, because u have a larger displacement. u need more fuel tho, a larger combustion chamber need more a/f to work out rite
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
justcruzin125
Aug 11, 2015 09:09 PM
