Dezod does it again....(V3 results are in w/ DYNO)
Old Aug 8, 2006
  #91
dezod's Avatar
7thgen Power Maker
Originally Posted by trurace
I think a T28 would be nice on a manual, while still making nice power and spools almost instantly. With our auto a fast spooling turbo might make the tranny slip. A t3/t4 spools a like 4-5k rpm and our tranny holds power in the mid range without slipping. Like dezod said too much torque down low would make the tranny "soup" very quick.
IMHO a GT28 BB would out perform a t3/t4.
CFM rates determine which will make more power. Out perform how?
Old Aug 8, 2006
  #92
trurace's Avatar
trurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the rough
Spool time, I just like fast spooling turbos that is why I said IMO.
Just wondering, why did you decide to go with T3's for the D17
Old Aug 9, 2006
  #93
dezod's Avatar
7thgen Power Maker
Civic are top end lackers HARDCORE. They need some upper RPM love from persay 4K up. So that is why. Esp the auto guys. The autos are dogs on a straight highway punch from 40, 60 or 80
Old Aug 9, 2006
  #94
trurace's Avatar
Yea, VTEC only does so much
This might sound really stupid so correct me if im wrong. I was talking to a friend of mine and me was saying, turbos are better on auto's because they hold their boost rather than releasing it between shifts like manuals do. Is this true.
Old Aug 9, 2006
  #95
dezod's Avatar
7thgen Power Maker
That is correct.
Old Aug 9, 2006
  #96
trurace's Avatar
That is correct.
So from say 30-100mph a auto would have an advantage over the manual? (both cars boosting)
Also. I don't think anyone has asked you yet, but what is your pick for engine managment for the D17. E-Manage or PCS, and why? Does both systems have their advantages and disadvantages?
The numbers put down with thee PCS are very impresive, and for $600(with PNP harness) for an engine managment that is pretty close to standalone is a deal IMO
Old Aug 9, 2006
  #97
dezod's Avatar
7thgen Power Maker
Assuming all else equal: power, weight, driver, tune, octane, turbo, kit and all....The auto should win.
With respect to the EMS, I would go PCS all the way on the D17! Hands down.
E-manage Pros:
We all know how to use it
Proven to work for the most part
Settings and various tunes are publicized
Readily available
PnP available!
E-manage Cons:
data-logging kinda sucks
units are inconsistent
support tool is extra (without it makes it useless)
no target tune
no O2 sensor manipulation
no control over fuel pressure
PCS XFC Pros:
O2 sensor skew (prevent relearning)
Has a fuel pump kit that it can control
Datalogging is top knotch
Target AFR ratio (self tuning to an extent if you have a wideband)
Software included
PnP available!
Proven to work and work well on the D17 with a near stock feeling
PCS XFC Cons:
New to market--people still learning about it
Fuel kit not included
No timing adjustment--Throwing more fuel pressure helps eliminate dentonation
Cost break down:
E-manage:
Main Unit $300
Support tool $125
PnP harness $200
Pressure sensor $115
Pressure sensor harness $48
Total $788
PCS XFC:
Main unit w/ software $500
PnP $100
Map Sensor $50
Fuel Pump Kit $175
Total $825
In my eyes, the $37 difference is worth it's weight in gold. Not to mention PCS's tech support is 2nd to none. Unreal!!! GReddy could only dream to be that good.
We had an 11.5:1 tune on an IS300 and it was dentonating with the e-manage, and we had to retard timing.....
We had an 11.5:1 tune on an IS300 with the PCS, and it was not dentonating because we threw a bit more fuel pressure into the system and not a trace of dentonation. The higher fuel pressure causes for good fuel atomosation. Also, the partial throttle response between the units was not even close. The PCS drove like a stock turbo car.
+rep it up if this helped
Old Aug 9, 2006
  #98
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
cool! reped ya dezod!
Old Aug 9, 2006
  #99
trurace's Avatar
Wow. Thanks Dezod that helped ALOT.
825 for EMS is a alot for a piggy back. $200 more you could just get a standalone. Isn't a Walbro fuel pump only like $105, and is the map sensor necessary?
Do you think that PCS is responsible for those numbers WilmncChris put down? Maybe a combo of your new kit+PCS? What do you think?
LOL sorry for all the questions
Old Aug 9, 2006
  #100
WilmncChris's Avatar
WilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of light
Trurace, hey i do think that the PCS is a big part of why i put down good numbers. I mean if no ones ever tries new tunning products, we never move foward. I thought was this, Dezod is advancing their d17 turbo kits so why not go with a new fuel managment system that could possibly give me more than the usual setup.
Old Aug 9, 2006
  #101
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
No, last I checked the AEM EMS was around $1500. I havent even used the pcs but I already recommend it over the emanage lol. I hated that thing.
PCS XFC Cons:
You could use the emanage for ignition timing only and use pcs for everything else hehe. IF you gonna do that then might as well go EMS.
Old Aug 9, 2006
  #102
army12bc's Avatar
army12bc will become famous soon enough
where can i get one????????????
Old Aug 9, 2006
  #103
dezod's Avatar
7thgen Power Maker
AEM EMS is more than $1500!!
The timing adjustment is not needed if you add more fuel pressure from the fuel pump kit. Trust me from experience.
Old Aug 9, 2006
  #104
trurace's Avatar
LOL nevermind I take back my previous post.
Old Aug 9, 2006
  #105
dezod's Avatar
7thgen Power Maker
http://dezod.com/cat_pcs.cfm
http://dezod.com/pd_dezod_motorsports_pcs.cfm
Old Aug 9, 2006
  #106
trurace's Avatar
I thought the fuel pump kit was $175. It is $250 on your sitem, is the map sensor included? What makes PCS's fuel pump any different from all the other fuel pumps out there?
Old Aug 9, 2006
  #107
army12bc's Avatar
what about the stuff that cost $825 and ECU and fuel system. what kind of fuel system do i need?
Old Aug 9, 2006
  #108
dezod's Avatar
7thgen Power Maker
The $825 as a whole is the package price break down of the entire system. If you buy each individual piece for it, it comes out to more. The fact that it is controller soley on, off and pressure by the PCS XFC is what makes it different. It can be done versus boost, throttle position.....FULLY PROGRAMABLE!
If you bought our turbo and the XFC, just scoop some used RSX Type S or RC eng 310cc injectors and hook 'em up and your done!
Old Aug 9, 2006
  #109
Not lying the PCS is the way to go!!!! Hate to say it but spend the extra money you will like the outcome
Old Aug 9, 2006
  #110
_Viper_'s Avatar
how much canadian ????
must be an arm and a leg!!!!!
Old Aug 9, 2006
  #111
dezod's Avatar
7thgen Power Maker
For the turbo system or PCS?
Old Aug 10, 2006
  #112
_Viper_'s Avatar
the turbo system of course
Man you are like a God on here
Old Aug 10, 2006
  #113
Logan3024's Avatar
Old Aug 10, 2006
  #114
dezod's Avatar
7thgen Power Maker
Sure we can send it north of the boarder. Not a problem. The kit roughly starts at $3,585.28.
Old Aug 18, 2006
  #115
civiccontend34's Avatar
civiccontend34 has a spectacular aura aboutciviccontend34 has a spectacular aura aboutciviccontend34 has a spectacular aura about
D17 turbo
I noticed this new Chris kid put down some pretty amazing numbers from your new kit and awsome job. I am interested in getting a kit soon but realize I might aswell just wait until after winter as it would not be fun to get your new turbo installed in winter when it would be shitty out in Canada. Wondering how much you would charge to ship to Hamilton Ontario for the kit? Also is there no duties on these kits because according to NAFTA anything produced in the USA can be shipped tarrif free across the boarder and technically alot of hte kit is custom? if you could PM me that would be greatly appreciated.
xproductionz
60
Jan 31, 2013 05:23 AM
skipbarber
Mar 11, 2009 08:29 PM
dopes6070
Engine Swaps
184
Oct 23, 2007 02:54 PM
ofourcivic
Sep 25, 2004 09:24 AM
