K20/k24 automatic?
Old Jul 20, 2006
starstryke's Avatar
starstryke is an unknown quantity at this point
Lightbulb K20/k24 automatic?
I did a search with no relevant results.
I want to do a k20/24 hybrid swap but I also want my girlfriend to be able to drive the car as well hence this topic.
I was wondering if I could use the 2wd k24 auto tranny instead of the manual for this swap? What complications would I see with this idea? Any help is appreciated since well, I'm serious about this.
If the k24 2wd auto tranny isn't an option, does something exist that will work with this swap? Would a RSX auto tranny with a levelten.com kit work well?
I bookmarked the k20/k24 diy but it's for a manual transmission.
Old Jul 20, 2006
RHCP0801's Avatar
its a waste
didnt someone make a thread about this before?
Old Jul 20, 2006
starstryke's Avatar
I was a post about a standard rsx swap and the guy wanted to use an auto tranny with it. I was just curious if I have to use a k24 auto tranny for the 20/24 hybrid. I am starting to feel like this might not be worth it and I might as well go trade in the vic and buy something with prebuilt muscle to tune.
Old Jul 20, 2006
RHCP0801's Avatar
it wouldnt be worth it. Just get another car if you want speed or teach your girlfriend manual, its not that hard
Old Jul 20, 2006
Civicman1988's Avatar
theres no automatic transmission for a K20
Old Jul 20, 2006
texascivic2k1's Avatar
THE LONE STAR STATE
texascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of light
Then what does the base RSX automatic have????..... K20
Old Jul 20, 2006
starstryke's Avatar
that's not what I was asking, I was considering a k24 auto tranny for the accord
Old Jul 20, 2006
CenZ's Avatar
PWIT
in all theory it will work. but fitmit wise, the k20/k24 takes alot of room as is it is. the k24 auto tranny will be bigger than the manual one. so you got to look into that.
Old Jul 20, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Well it would be a good braket racing car, just mash gas and go.
Old Jul 20, 2006
CenZ's Avatar
PWIT
do it, be orginal. you will still have fast vic. and when you own some little ricer you can be like. yeah its an auto. lol
Old Jul 20, 2006
starstryke's Avatar
I looked around at the g35 and the newer IS350 and buck for buck I can make my car faster and have much cooler gadgets. I am an electrician's apprentice so I think I'll have fun with the ICE.
Thanks for some relevant replies, I'll check into that fitment issue. I've heard that the k24 tranny is slightly larger so I hope no custom fabrication will be needed.
Old Jul 20, 2006
Vantage's Avatar
Vantage should not be trusted
if $$ is a problem get a 97-01 Prelude tiptronic. Or hell, any tiptronic for that matter is better than full auto.
97+ preludes are cool tho, h22a is a strong *** engine.
Old Jul 21, 2006
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
mmm but what ecu would you use for this swap, a k20/k24 would require kpro to work correctly and Kpro cannot be used on Automatic ECU's...
Old Jul 21, 2006
CenZ's Avatar
PWIT
^^ good point. maybe call the company and comfirm.
Old Jul 29, 2006
TemjinX2's Avatar
just buy a k24a2. It comes in automatic stock and has 200hp.
Old Jul 29, 2006
HondaLuver's Avatar
Its a celebration bitches!
diffrent mounts, and there is too much wiring BS.
just teach her how to drive, is she really that stupid? if she doesn't learn in less then 2 hours, find a real gf that can learn...
Old Jul 30, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
this true.. here is how i see it
if you want to be automatic you cant use any type of k20/k24 hybrid cause that would require you to use kpro. also doing engine modifications is out of the question cause that would require kpro.
you can however could?? or should be able to use a straight k24 automatic motor from the accord.. its basically ALMOST the same swap as the k20/k24 manual swap but i cant directly point out what other things will need to be done other than the wiring on the k24 ecu is different than the k20 ecus..and you are going to have to use the k24 ecu... BUT.. if you do you would have to get the ecu reflashed at the dealer to bypass the immobolizer.. and dont expect high HP gains from the motor other than having a torquey motor in the car just because you decided to make it an automatic
Old Jul 31, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Please dont do that.
Just teach her. Tell her how everybody in england drives stick, and it is really not that hard. Alot of it is just the mind set of the person learning. After a month or two she wont even notice it.
Old Aug 6, 2006
starstryke's Avatar
might not be a bad idea... would be a ton cheaper and the fact that it's 2.4 means bigger hp gains from bolt ons.
Tyler93
Mar 20, 2016 09:03 PM
danace99
Oct 17, 2015 02:51 PM
cferry7
Oct 3, 2015 04:33 PM
General DIY
Sep 25, 2015 08:02 PM
blizza
Sep 22, 2015 03:48 AM
