Why boost not building?
Old Jun 3, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Could there be another problem other than faulty gauge?
Today I was driving and noticed that my electronic (digital readout) boost gauge stayis in vacuum and reads -29 at any rpms.
My injector unit depends on this gauge reading (eg its dumping extra fuel when gauge reads preassure), since preasure not rising engine not getting any extra fuel (the fuel reading shows its not adding any).
p.s. I'm not driving my car at this time.
Thx
Old Jun 3, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Well I'd check the vac line and see if it blew off. Check to see if there's any crud in the port as well.
Getting a new sensor would be the easiest place to start, but if you can do any diagnostics on the one you got (checking the resistance readout etc... ) then do that first.
Even when the car is in vac it should be moving around, so something is definitely off with the gauge itself.
Old Jun 4, 2006
The vac lines are checked ant are fine.
I'm set now that its the gauge thats giving me issues.
I tried resistance on the vac line (I used my finger) It does "suck in" my finger when I rev, so preasure changes, but gauge always read -29.
...I took appart the gaude and there was that little black sensor where you attach the vac line. I'm thinking it might be just "closed" from reading or just "stuck" in one position.
Can I just drop little lublication inside this sensor via vac line out and see if it helps?
Old Jun 4, 2006
dezod's Avatar
7thgen Power Maker
Do you hear your BOV sound? DO you hear the turbo spool? Check your charge pipes too....
TSI crap........
Old Jun 4, 2006
Now I'm sure I have boost, I can hear BOV, turbo etc.,
I'm convinced it is the gauge.
Old Jun 4, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
29 vac is also really high....should be around 18-22
bowie
Jan 21, 2018 09:29 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
C-Hamm
Sep 28, 2015 10:31 PM
99BoostedSi
Sep 7, 2015 04:49 PM
