k20a or f20c?
Old Apr 22, 2006
o0vk0o's Avatar
o0vk0o is an unknown quantity at this point
k20a or f20c?
found a k20a engine but dumb expensive, $5K+ but the place gives everything needed for the swap.
they also had a f20c which was half the price of the k20a but i'm not sure if it fits into my '03 civic ex cpe. im running on a A/T and basically converting to a M/T so can anybody tell me what might be needed and what changes must be done to my engine bay to fit a f20c if its even possible?
Old Apr 22, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
It would cost a lot, too much IMPO.
I would get a k24 and the k20a or a2 transmission and spend the rest on FI.
Old Apr 22, 2006
R1Style's Avatar
F20C is not a straight bolt on. Have fun with that, you would have to custom fab mounting brackets...the motor sits at a 90degree angle and I don't even know if it will fit without having to hack away at the firewall or rad support. Plus you'd have to convert your car into RWD which means you'll need a drive shaft, rear dif, axels, relocate your fuel tank... and a **** load of other parts. I could go on for days.
It's definatly not worth it... get the K20
Old Apr 22, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
lol that would be cool a f20 civic drifting
Old Apr 22, 2006
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
the f20c bolts to the k20 tranny... so you can fwd it but can the k20 trans take the f20's rpms? ...
theres a thread on it here or somewhere but someone found out that the f20 bolts to the k20 tranny.. so you can fwd it .. but the mounts and that ****...
the f20 into a fwd trans and into our vic is a complete PRO only job i would say..
im doing the k20a3 swap for the lower compression seeing how im doing forced induction... the k20a3 is around 1500 bucks for motor and stuff where as the k20a2 is more expensive.. im doing FI and the lower compression of the k20a3 is more economical for my budget and plans ...
but its his call.. the f20 does bolt to the k20 tranny but GOOD LUCK on getting into the civic.. also the wiring would be different too..
id say do a K series swap if your interested and theres more than enough info on this site about it...theres a DIY , all the info you need on aftermarket accesories for the new motor into your car.. and everything.. even the wiring diagram for the behind the dash re pinning of the gauge cluster to make the RSX or Civic Si ECU display the correct info...
good luck on your swap tho ..
Old Apr 22, 2006
TheSmuggler's Avatar
R1, dont say it wouldent be "worth it" because it WOULD
Old Apr 22, 2006
o0vk0o's Avatar
damn so the work/$$$ involved with doing a f20c swap would be really high then. only reason i asked was because i coulda gotten it for half the price of the k20a...
a f20c vic would be nuts but for the amount of money involved i think i`ll just settle with the k swap. (at most $9K for parts/engine/labor) =x
Old Apr 22, 2006
jackburton's Avatar
I also heard that the head gasket pattern is the same so you could put a f20 head on a k20.
Old Apr 23, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
well here is how i see it.. by the time you are done getting everything custom made to make a f20 to fit in your car... the cost would be the same.. if not more than the cost of putting a k20 into your car.. it would be nice... but if you run into any problems you wont have much support from us about it.. THINK ABOUT IT
Old Apr 23, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
around $1,500 for a K20a3? th full motor???
Old Apr 23, 2006
Bad_Civc's Avatar
where ive seen it on ebay... and junkyards that have em and a website..
im talkin K20a3 ( Civic Si Motor ) not the RSX motor.. but ive seen em for that. hell i almost bid on one on ebay for 1250 the full swap.. motor , trans , radiator , sub frame and the under hood harness..
Old Apr 23, 2006
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
f20 also comes in the european accord/tsx so they are fwd and you can buy a combo tranny and engine.
Old Apr 23, 2006
Yeah I know its the 02-04 civic si motor, but i dident know u could get the full swap for around $1,500. i was think just the motor, no sub frame, shift linkage. i need 2 go check out some junk jards. i was thinking of going turbom but now i could go swap and turbo..
See I was always looking at the K20a so it was aton of $$
Old Jan 27, 2007
DragassD's Avatar
DragassD is an unknown quantity at this point
What's the difference between the si motor and rsx motor? Thought they were the same
Old Jan 27, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
It bolts up with an adapter plate, not directly.
Anyways, this seeminly silly question has been asked before, repeadly, by many overly ambitious newbies. Search it.
C-Hamm
Sep 28, 2015 10:31 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
APME123
Nov 28, 2003 02:37 PM
HondaLuver
May 26, 2003 04:30 AM
S2000man01
Feb 28, 2002 07:34 PM
