Aem Or E-management For Turbo Set Up
Old Jan 28, 2007
ST8RACE's Avatar
ST8RACE has a spectacular aura aboutST8RACE has a spectacular aura aboutST8RACE has a spectacular aura about
IM TRYING TO DECIDE WHAT ENGINE MANAGEMANT SYSTEM TO RUN . I THOUGHT PUTTING THIS Q: UP WOULD GET SOME POSITIVE AND NEGATIVE FEEDBACK. IF YOU THINK NETHER OF THESE SYSTEMS ARE NO GOOD IM ALL EARS FOR RECOMMENDATIONS. THANK YOU
Old Jan 28, 2007
flashchat's Avatar
flashchat is an unknown quantity at this point
I'M TRYING TO FIGURE OUT WHY YOU DECIDED TO POST IN ALL CAPSLOCK!!!
of course everyone will say AEM EMS that thing is wonderful.
Old Jan 28, 2007
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Theres no negatives for the AEM EMS other than that its expensive and not everyone can tune it. It is a standalone, you tune it how you want and it STAYS that way, no stock ECU that works against it. It can set your own rev limiter, boost control based on gears, 2-step launch control to name a few. These things the Emanage can't do.
The Emanage piggybacks the stock ecu, essentially "tricking" it by intercepting the voltages that the stock ECU sends to the motor, changes them based on your input. The problem being is that the ECU fights back the changes you make making your tuning a big headache. Its a good setup for the basic booster but I wouldnt recommend it if you plan on going above and beyond 8-9 psi or 200+ hp.
Bottom line you get what you pay for. Theres a reason why the AEM is $1600(?). Figure out your goals for the setup then start from there. The AEM will always be the better choice over every piggyback hands down. The adjustability is just unmatched.
Old Jan 28, 2007
drunkenmagnum's Avatar
u can run 10psi fine with emanage and u can make 200+whp but EMS is the better of the two. i run emanage now and it works fine for me. i recently went ultimate too and am waiting to get the car back from the shop.
Old Jan 28, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Reviews of both are posted, multiple times. Just search for it.
carid
Nov 7, 2015 01:46 AM
justcruzin125
Aug 11, 2015 09:09 PM
spyder13
Jul 31, 2015 06:31 PM
Misfit2613
Jul 30, 2015 09:49 AM
Theshwartz35
Jul 17, 2015 11:13 PM
