Manifold nuts not holding tight
Old Apr 13, 2006
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
No matter what I do to the left bottom nut on my mani it just seems to come loose after driving. I need it to hold good before i go to the dyno....anyone got any suggestions?
Old Apr 13, 2006
TheSmuggler's Avatar
You sure the threads didn't take a crap?
Old Apr 13, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
clean the stud w/some degreaser, use thread lock and a lock washer
Old Apr 13, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Thread lock will melt off unless you get the high temp stuff. Use a lock washer or get locking exhaust nuts.
Old Apr 13, 2006
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
just replace the stud with a new one. just think if you have to take that nut off one day then it might not come off if you put threadlock on it.
Old Apr 13, 2006
iamboo's Avatar
Retired - SoCal FI Mod
JB weld the manifold to the head...
j/k...
Old Apr 13, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Definately dont use JB.
Use lockable washers as some one said.
Also check stud/nut for threads, as you might have striped'em.
Replace stud/nut if necessary.
Old Apr 13, 2006
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
manifold could be bend.
Have it rec.
But deffinately change the stud.
I did mine to a number 10 stud 1.25" long.
Bore it out then place in with
Old Apr 13, 2006
joshb_'s Avatar
Boosted 04
Have it rec.
the mani is perfect i just got it and the surface was very good. I took the nut off and put a **** load of lock tight on and torqued it pretty good and its now holding...i guess we will see what happens.
Old Apr 14, 2006
supermex's Avatar
Good luck I hope it works.
This is going to be a future problem with boosted 7thgens all over.
The stock studs are too small and weak to hold the wheight and kinetic forces of the turbo at full spool.
Specialy after removing the bolts once or twice during install.
I had that happen to me in twice and took care of it with a set of five ARP #10 studs but ACE hardware have them too at lower price.
I did it with while P&P the head.
That biach is not going anywhere and the ARP's can be reused over and over without loocktight.
If is only the nut coming lose ARP has a set of nut looks for $2.00 each
Keep an eye on it an look for signs of carbonation on the bottom of that nut.
The nut could be tight but the strut may of came lose inside the head.
In that case the nut can be tighten again and again till the end of that side of the stud.
Also beware that is hard to tell when a manifold is straight or bend just by looking at it without close measurements.
New stuff can be defective too.
Old Apr 14, 2006
joshb_'s Avatar
Boosted 04
I dont under stand why they went to the 5 bolt pattern, its so much weaker
Old Apr 14, 2006
Jap-Euro Fusion
because its good enough for the car in stock form, and drilling/cutting 5 holes, then the subsiquent bolting operation is faster than lots of holes, therefore cheaper.
Old Apr 14, 2006
blouisgod's Avatar
Life Begins > 6800rpms
i was gonna say just use the lock washer or simply get another bolt and drive it against the first one. well see what happens.
Old Apr 14, 2006
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
you might need new studs and nuts which is about $22 dollars for all five from the dealer, and while your at it heat wrap your header if its an aftermarket header. and if that doesn't do squat... just get locking washers. MIne kept getting loose after every drive with just my header and catback. I damper (engine might help but i dunno)
Old Apr 14, 2006
joshb_'s Avatar
Boosted 04
yeah...i got a price at work today...it was 8 bucks for them all cause im a tech at a acura dealer.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
PierrePierre
Aug 12, 2015 02:42 PM
WaryDriver
Aug 8, 2015 05:08 PM
17
Jul 23, 2015 11:48 PM
califcamper
Jul 21, 2015 10:34 PM
