im frustrated.... but i have boost now.
Old Apr 10, 2006
  #31
tuner04civic's Avatar
spell check pwns you
looks good sorry to hear the problems and keep it alive
Old Apr 10, 2006
  #32
turboengnr's Avatar
DONT PANIC
alright. FINALLY fixed the exhaust leak problem today. Basically, the stock donut would not hold the amount of flex the engine was placing on it.
soooo.....
I replaced that donut with a much larger one, and i also added a stainless steel braided flex section just after that.
And, i have to say that 7 psi feels quite good. I missed it.
The turbo comes on late. The boost guage registers positive pressure at about 3000 rpm. I make 7 psi at 4500 rpm. But that was to be expected with the stage III wheel and with the turbo this far off.
And Dezod, I did think about you while i had the header off...
I looked at the collector, and the person that had it before me ported it. It was seam welded then had a flapper wheel ran through it. So it is a nice collector.
I got my camera back from bestbuy yesterday (it didnt turn on anymore), and i put 2 brand new batteries in it, and it did the same thing. So i still cant take any pictures unless i am at my dads house. But my Dad is in an 'undisclosed location' working on a project for Northrop. So he isnt home to help me. I had a muffler shop install the new gasket and flex section. Another $65 i didnt plan on spending. But i know it would have been a lot more if i wasnt a former employee and good friends with the owner of that shop (the place i originally got all my welding experience from in high school)
Its kinda funny. He taught me how to MIG weld. And when i went in there today, they had just got a TIG welder. So i was teaching them how to TIG weld while they were working on my car.
Old Apr 10, 2006
  #33
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
hey, what this do?
Old Apr 10, 2006
  #34
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
yeah really what is that?
Old Apr 10, 2006
  #35
MajinB's Avatar
Drunken Master-7thgen Ninja
oil collector?
Old Apr 11, 2006
  #36
turboengnr's Avatar
DONT PANIC
No. It is the surge tank for the radiator. I had to take mine out to clear more room for my downpipe. So i made a nice aluminum one. It holds the same amount of fluid as stock.
also, my boost has fallen down to about 4 psi. the wastegate isnt opening. Im not hearing any more exhaust leaks, so i believe i have some boost leaks. This doesnt suprise me though. I am still waiting on several proper couplers. I am waiting on 2 2.25" couplers and 2 2.5" couplers. Right now i am using the 3" couplers you can buy from autozone on those. So im sure they are leaking. But i will get them fixed as soon as i get my new couplers.
Also, i will mention that the TiAL blow off valve is not a good choice for those of you running low boost. The valve has a slower reaction rate which causes compressor surge at lower boost levels. This BOV is rated at 80 psi and is meant for use on cars running more than 10 psi. So use on a stock civic is (in my opinion) not recommended
Last edited by turboengnr; Apr 11, 2006 at 03:38 AM. Reason: Automerged Doublepost
Old Apr 11, 2006
  #37
XSRCivic's Avatar
interesting thought about the tial BOV. is there no way to adjust the release time? is there a typical sound that compressor surge makes. I've heard it referred to as the rattle snake sound.
Old Apr 11, 2006
  #38
iamboo's Avatar
Retired - SoCal FI Mod
good **** mike...hope everything works out for you...
Old Apr 11, 2006
  #39
turboengnr's Avatar
DONT PANIC
compressor surge sounds like a damn turkey.
and no, the Tial bov is not adjustable.
Old Apr 11, 2006
  #40
dezod's Avatar
7thgen Power Maker
It is by spring. There are 3 or 4 spring choices. They adjust the stifness.
Old Apr 11, 2006
  #41
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Wow! Best luck there!
Hope the 7th gen will still live on!?!
Old Apr 11, 2006
  #42
blouisgod's Avatar
Life Begins > 6800rpms
the only thing normal looking about that engine bay is the wire cover and the power steering stuff looks sweet and i like the metal coolant resevior too.
Old Apr 11, 2006
  #43
turboengnr's Avatar
DONT PANIC
ah. didnt know they offered different springs.
Old Apr 11, 2006
  #44
01HonderCivic's Avatar
Don't be a n00b, search ftw
Turboengnr, I was thinking. Since you don't have ABS on that car, Why not put the air filter in that spot and run a tube behind the IM and to the compressor housing? I may just be talking out my ***, but I went out to my car and you might possibly be able to do that. Here's a rough drawing
Attachment 65708
Sorry if this sounds retarded to you, Just a brainfart I had looking at that pic...
Old Apr 11, 2006
  #45
iamboo's Avatar
Attachment 65708
it would almost be like a cold air intake.. the only problem that i see in your design is that he would have to loop the steel braided fuel lines over the tube or build a narrow 2" pipe that would clear it....
plus there would be some air lag because of the length of the tube from the turbo to the other side... it's like going snorkling with a 4 foot snorkle....
the car has a hard enough time making boost now, i think with the longer intake, even if it's turbo charged, would make make it a bit more difficult to hit boost toward the bottom and middle end of the power band...
Old Apr 11, 2006
  #46
XSRCivic's Avatar
i got that turkey sounding BOV
Not good news. But it doesn't feel like "trailor hitching". I just here the sound.
Old Apr 11, 2006
  #47
turboengnr's Avatar
DONT PANIC
The length of the air intake tube is very crucial. Turbos have no problem blowing through piping. But they do not like sucking through them.
Im pretty sure i still have a small exhaust leak. But i am going to fix this permanently this weekend. And i should have my couplers, so that will also be fixed.
But some good news on another subject.....
Just recieved the T56-6speed conversion kit from Keisler Automotive for the 56 belair. So we can finally drop the built motor and trans in that! All we have to do is drop it in and measure how long the driveshaft has to be, then send them the measurements. So the 56 should be up and running by the end of this month!
Old Apr 11, 2006
  #48
ncirom2003's Avatar
thats a strong transmission, have fun. thats used in the 03 rustang cobras, tkae alot of abuse.
Old Apr 11, 2006
  #49
turboengnr's Avatar
DONT PANIC
it is the tranny out of the camaros and the corvettes (well the corvette was a transaxel, but you know what i am saying...)
But ours has been custom machined. It is not a used transmission, it is one that is brand new then custom built/machined per our specifications.
Old Apr 11, 2006
  #50
ncirom2003's Avatar
im sure they used it for tons of things, i know in particular that the "terminator" like 02-04 cobras or w/e use them also. unless im confusing it with the mach 1's, either the t5 or t56........i think the t5 is the stronger one in the cobras.
but either way, lets see a thread bout this bowtie your building. sounds nice.
Old Apr 12, 2006
  #51
turboengnr's Avatar
DONT PANIC
i had a thread about it.....
heres some pics of the parts going in the 56!
SRP 10.6:1 pistons
eagle rods
eagle crank
ARP bolts
Edelbrock performer RPM aluminum heads (2.02" intake and 1.60" exhaust valves)
Moroso 7 qt oil pan
Old Apr 12, 2006
  #52
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
keep that in the other thread more about the trubo in this thread stop jacking ur own thread. j/k....... hope everything turn out ok .........from all this i think i am going to boost also but i am want to see more people do it and look at there problems then build mine.
Old Apr 12, 2006
  #53
diskreet's Avatar
Good luck this weekend. Hope that everything gets up and running for good already. You have been through a lot!
How are you able to drive a manual with your shoulder, too?
Old Apr 12, 2006
  #54
ncirom2003's Avatar
thats awsome, i remember tearing my head apart thinking how tiny the valves are, cus the last thing i took apart was a sb350 huge valves^ lol
anyways back to the vic. good luck with all and keep updating.
Old Apr 12, 2006
  #55
turboengnr's Avatar
DONT PANIC
i simply steer and shift with the same hand. I can hold the car straight with my left arm. I just cant steer with it.
And yea, the SBC valves are pretty large. We have the big valve heads (2.02" intake, 1.60" exhaust) for the 56.
bowie
Jan 21, 2018 09:29 PM
UltraHDGames
Jun 8, 2016 05:16 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
