T3/T4 or T25?
Old Apr 8, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
T3/T4 or T25?
Witch turbo is best to get for our D17? I searched the thred and I could not really find anything to help.. Thx...
Old Apr 8, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
It depends.
What are your goals?
Old Apr 8, 2006
I want to be quick off the line, i only want around 300 to the wheels. And I was going for the Dezod kit, but some friends are telling me that the t3/t4 dont spool up till 4,000 RPM's. im j/w if thats true?
Old Apr 8, 2006
jdgoodwi's Avatar
jdgoodwi is an unknown quantity at this point
well, you won't be that quick off the line anyway you slice it, but if its that important then I guess I'd go the t25 route, but to get to 300 hp on that is just not realistic.
There are only a couple of guys on here that get that kind of power off of the d17, but if thats a serious goal, you need to upgrade from the stock internals.
this should help -
http://www.7thgencivic.com/forums/sh...d.php?t=168101
Old Apr 8, 2006
yah i know that, im gunna be building the motor. im j/w about the turbo. cuz my friend has a 97 civic SOHC and hes all stock with a t25 and he it sayin i wont beat him with a t3/t4. so idk
Old Apr 8, 2006
jdgoodwi's Avatar
its just a matter of preference then... you can obviously get more out of the t3/t4, but the t25 spools faster as you know. with the t25 your somewhat limited as far as gradually improving your numbers as you do more work. And your friend is dead wrong btw.
Old Apr 8, 2006
yeah i mean when he was stock and i was stock i beat him, hes got a d15 i think or d16. but can u make the turbo spool faster with a good tune? or how do u make it spool? sry im trying to learn, thx alot..
Old Apr 9, 2006
turboengnr's Avatar
DONT PANIC
tuning effects everything.
for example.... If you pull 10 degrees of timing out at zero vaccum up to about 3 psi of boost, the turbo will spool insanely fast. But this can cause damage to your exhasut turbine since it is dumping much much hotter exhaust gasses into the turbo.
Theres a ton of things you can do. But ill guarantee that if you know how to drive your car, you will smash him if you have a T3/T4 and he has a T25.
Old Apr 9, 2006
Under 200whp = t25
Over 200whp = t3
Old Apr 9, 2006
dezod's Avatar
7thgen Power Maker
True. Commonly referred to as an Anti-Lag tune.
A decently tuned T3/T4 will destroy a T25 on the same boost levels and even a bit more boost on the T25.
No, it does not necessarily spool at 4K. All depends on the tune & exhaust A/R on it.
Old Apr 9, 2006
Small turbine as t25 cant move enough colder air on high rpms to create healthy top end gain as t3/t4.
But most certanly t25 will destroy t3/t4 in regular city driving (not racing).
Also smaller turbo creates impression for the driver, as "there is turbo on this car and I can actualy feel it and use it without revving engine to much".
Just to give you a clue:
d17 + t25 = feels like big v6 with pushrod engine (good low end power, so-so top end)
d17 + t3/t4 = feels like b18/k20 (slow off the srart, nice top end)
Old Apr 9, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
and u don't want to hit boost off the line. u will just spin all the way of 1st and some 2nd.
Old Apr 9, 2006
yah i see what you all are saying.. So what about in a 1/8? and 1/4? witch would be faster?
Old Apr 9, 2006
dezod's Avatar
7thgen Power Maker
Yes and no. A smaller turbo does give a more constant and mild throttle response than the T3/T4. Yes this is true all day. However, if you want to really be impressed and rifle someone into the seat when the pedal is mashed through the floor boards of the car, a T25 does not stand a chance. A T3/T4 will sling you into the back of the seat a hell of a lot more and easier than a T25. Remember, MOST OEM vehicles: Beetle, Eclipse, Saab....All have T25s. If you floor it in the car, yes it is moderately quick........Hell it better be because you paid $$ to have a turbo, but show me one decent power making car with a T25 that someone keeps. Even EVO 8s are switching to T3/T4s now and making SERIOUS power.
One more thing to consider. More frequent boost puts more wear and tear into the motor that is not designed to handle it.....Food for thought. So lagginess could be a good thing, but a tune could even solve that.
Old Apr 9, 2006
I know what you're saying.
The head snapping acceleration does feel great, I agree.
But you cant beat smoothness of a small turbo. You just dont get jumpy feeling, where car suddenly starts to accelerate with much more force.
Small turbo on the other hand, provides a surge that lasts a tad longer and therefore simulates agreater acceleration that actualy is.
Old Apr 9, 2006
Thank you all for your imputs this is really helping me..
Old Apr 9, 2006
Alex1's Avatar
T3/T4 for sure! Do you know how frustrating it is to have the power band drop before redline?
Old Apr 9, 2006
what? with a t25 it stops before redline?
also now that i see all these people with K24a1's with 220whp with just
i,h,e its geting me thinking on getting a k24 then turboing it. that would
put down some good #'s woulden it with a t3/t4?
Old Apr 9, 2006
No, its just called wide powerband.
Old Apr 9, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i look at it this way...if it doesn't spool til 4 k, and you normally drive around around @ 3k or so (civil driving habits), you're not in boost, but the potential is there if you're feelin' froggy....
Old Apr 9, 2006
Yeah but i would like it to be a little lower for racing around town..
Old Apr 10, 2006
turboengnr's Avatar
DONT PANIC
the t3/t4's can make boost pretty low. Like you could see 3 or 4 psi at 3200 rpm. Its just they dont make FULL boost until later.
Old Apr 10, 2006
ok i see. how much hp can a t3/t4 handle?
Old Apr 10, 2006
dezod's Avatar
7thgen Power Maker
Depending on trim, inducer, exducer bore......Each is different.
Old Apr 10, 2006
I see.. how much bigger in size wise is the T3/T4 then the T25?
Old Apr 10, 2006
jknudsen's Avatar
MAVS FAN 4EVER
jknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the rough
If it were me i'd go with a bigger turbo....just for the simple fact i think it is sick to mash the gas, have a lil bit of turbo lag then be slingshot forward...i agree with Dezod...i would love to have the daily drivability of my d17 and gas mileage, and save the boost levels for higher up in the rev range
Old Apr 10, 2006
yah def. cuz i mean if the T25 gets a t3/t4 off the line then t3/t4 is gunna fly past the t25 once it gets its boost up.
Old Apr 10, 2006
dezod's Avatar
7thgen Power Maker
Besides Civics don't race from a dig....
Not to mention, what RPMS are most of your racing occuring? 4K+ which is out of the T25's realm of power and where the T3/T4 shines.
Old Apr 10, 2006
lol we race from a dig around here, and from a roll, most of the time we do both when racing one car cuz people dont like to race just once, cuz they lose from a stop then try from a roll.. and what do you mean by out of the T25's realm of power?
Old Apr 11, 2006
May be you need to look into T28 turbochager family.
