Finally coming together.... Updated on Page 9!! Car is Turbod!!
Old Mar 21, 2006
  #61
turboengnr's Avatar
DONT PANIC
I got my new clutch in today!!!
Here is my new Exedy Cerametallic sprung hub 3-puck
Check out the fingers on the pressure plate! They are much thicker than stock, and they are double layered. This should have one hell of a stiff pedal.
Old Mar 21, 2006
  #62
Michalo187's Avatar
Abortion Survivor
Mike that clutch is super thick you better get an ankle support hahahaha.
Old Mar 23, 2006
  #63
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
What fuel pump did you use just out of curiosity?
Old Mar 23, 2006
  #64
turboengnr's Avatar
DONT PANIC
It is an MSD 45 GPH pump.
It SHOULD be enough to power ~500 hp @ 45 psi. But i was somewhat sceptical. But it was on sale, and with that savings it allowed me to buy a TiAL blow off valve instead of a Bosch one. So i am going to try it out, and if i run out of fuel, i will simply upgrade to a 65 GPH or larger.
Old Mar 23, 2006
  #65
Michalo187's Avatar
Abortion Survivor
Whats left to do mike?
Old Mar 23, 2006
  #66
mrDFWmechanic's Avatar
how much longer till we can see a video of the car in action
Old Mar 23, 2006
  #67
dezod's Avatar
7thgen Power Maker
Sexy clutch Mike. What kind is it?
Old Mar 24, 2006
  #68
C2i0v0i1C's Avatar
SuperMODrizd
take some smaller clearer picts
Old Mar 24, 2006
  #69
familycar's Avatar
looks like an exedy if its in a Daikin box
Old Mar 24, 2006
  #70
turboengnr's Avatar
DONT PANIC
It is an exedy cerametallic sprung-hib 3 puck.
I didnt know that the base plate was copper until i saw it in person. A good suprise when i saw it. It is ultralight. ACT was kinda pissing me off with their sponsorship. Last year they wanted to sponsor me, streetlight flywheel, 6 puck disc with extreme pressure plate.... all for $300. I told them i would pick it up when the motor was ready. So i re-submit my proposal, and they tell me the prices had changed. But wouldnt tell me how much i would have to pay. I went back to them (their office is literally 2 miles from my house) 3 times over 2 weeks, and couldnt get a price. So i said screw it and started searching for a different clutch.
Anyway, i have more updates. I was hoping to have the motor in the car today, but we lost a dowel pin for the clutch, then couldnt find the clutch bolts, then couldnt find the flywheel bolts, i had to buy $60 in misc fittings and steel braided lines, etc, etc, etc.
If you look close enough in the 3rd picture, you can see the built motor that is going in the 56. Only thing we are waiting on for that is the new carbon-fiber drive shaft and aluminum cross member, and flywheel to bolt the Tremec 56 6 speed in
Old Mar 24, 2006
  #71
C2i0v0i1C's Avatar
SuperMODrizd
that sure doesnt look like a turbo manifold on there
Old Mar 24, 2006
  #72
zachgeyer's Avatar
sweet
Old Mar 25, 2006
  #73
turboengnr's Avatar
DONT PANIC
you know exactly what i am doing. So dont go playing dumb.
Old Mar 26, 2006
  #74
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
why are the line from the fuel rail so long couldn,t be smaller.
Old Mar 26, 2006
  #75
turboengnr's Avatar
DONT PANIC
I couldnt get any more 1' -4 straight to -4 90* steel braid lines. So i am using those until they get more in stock.
Anyway, i have another update....
The motor is in the car, and ready to start. BUT, i dont have a serial port on my laptop so i cannot upload a base map. So the car cant start until tomorrow. But i did install the pressure regulator, and get the fuel pressure set properly. And there arent any fuel leaks with my new feed line installed. So that is nice also. I also found out that there is no way in hell that this thing will fit under the stock plastics. So i guess the whole under-hood sleeper thing is dead.
Here are some pictures....
Old Mar 26, 2006
  #76
drew22mader's Avatar
There is gl@ss in my @SS...
Very very nice man, i can't wait to see and hear this thing fire up and listen to her purrrrrrr. I've been watching the entire time and talking to ya about it. Believe me, i'm excited! I got my fingers crossed everything goes well.
Old Mar 26, 2006
  #77
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Mike, I had the same issue with my laptop. What I did was goto Radioshack and buy a USB-to-Serial adapter cable. It's around $20 but it will allow you to use a laptop through a usb port rather than the old school serial port. I can't wait to see this happen man, the skys the limit now! Awesome as usual.
Old Mar 26, 2006
  #78
iamboo's Avatar
Retired - SoCal FI Mod
you've still got the stock air box covering a lot of the fuel stuff and intake manifold... if the sleeper look totally fails on you then you should just make the turbo manifold and slap it on there like the other kits that you made...
you've come this far and i would suck to make a new one, lets just see how your sleeper setup would respond to boost and your fuel maps... see ya next weekend bro..
Old Mar 26, 2006
  #79
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Damn!
Old Mar 26, 2006
  #80
Michalo187's Avatar
Abortion Survivor
Yeah looks nice mike. I hope your cruisin in it right now
Old Mar 27, 2006
  #81
turboengnr's Avatar
DONT PANIC
I put an AMAZING 18 miles on it today.
Amazing is the only way to describe it.
Once i got the fuel map uploaded, it fired right up and purred perfectly. Interestingly enough, the car is quieter than it was before. It has a slight lope to it at idle, which i found interesting. But the clutch..... well thats another story.
The clutch is extremely aggressive. It grabbs much harder than the ACT solid-hub 6-puck that i used to have. It is a bit harsh, but nothing that i cant get used to. When downshifting, you MUST rev-match. If you dont, it will actually chirp the tires from the engine braking. Also, i have been rev-matching while up-shifting also, it makes for a much smoother shift. But i can actually chirp 3rd gear when normally shifting at ~50% throttle and 4000 rpm. It is nuts.
Anyway, there were no major problems today. I had a small fuel leak off my pressure regulator, but a wrench fixed that right up.
Oh yea, i also wired in the MAP sensor backwards, and had the wrong tach signal. So i fixed those quickly with no problems.
But the car feels very strong. I havent gone past 50% throttle, and not about 4300 rpm. And it feels noticably stronger than stock. And i am running an LX tranny now instead of the EX, and it still feels stronger than the stock D17A2 with the EX tranny.
I am way tired though. So i am going to build the rest of the turbo system next weekend. So this week will be all NA.
Old Mar 27, 2006
  #82
def01tones's Avatar
You bought a used dog??
def01tones will become famous soon enough
thats awsome news!! congrats on ur success!!
-blazed
Old Mar 27, 2006
  #83
Congrats man! I was asleep when you msg'd me about it. Hit me up tonight!
Old Mar 27, 2006
  #84
HyaBoosta's Avatar
congrats on the set up. sounds nice
Old Mar 27, 2006
  #85
C2i0v0i1C's Avatar
SuperMODrizd
weak
Old Mar 27, 2006
  #86
MajinB's Avatar
Drunken Master-7thgen Ninja
Originally Posted by C2i0v0i1C
weak
wait till april 9th. good luck turboengnr
Old Mar 27, 2006
  #87
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
good luck man, cant wait to see what it does boosted!!!!
Old Mar 27, 2006
  #88
dezod's Avatar
7thgen Power Maker
Let's see da boost already.
Old Mar 27, 2006
  #89
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Oooohhhh Aaaawwwwwwwwwwwwwwhhhhhhhhh
Old Mar 27, 2006
  #90
BOOST BOOST! you got everyone on the edges of their seats turboengr, i'll talk to you tonight if you don't get on so late lol
