Finally coming together.... Updated on Page 9!! Car is Turbod!!
Retired - SoCal FI Mod
Originally Posted by TransformedBG
what happens this weekend iamboo?
DONT PANIC
sorry for the late reply. I have been out driving it around. Just putting some miles on it. I went to my friends shop to show it off, and was invited to show it off in a car show on saturday.
I told him no. Im going to be busy with Dan building the rest of my turbo kit.
But it still drives great. The clutch seems to be breaking in nicely. It still chatters, but nowhere near as bad as before. I have about 130 miles on it now.
My wastegate has a 0.8 BAR spring. So the least amount of boost i can run is ~12 psi. So daily driving should be fun.
I am looking for about 15 psi daily once the car is completely tuned. But it should be fun.
Here is a short list of some of the parts i am using on my car. I have more, i just cant remember them off the top of my head. Also, i have a TON of XRP fittings im not including in here.
MSD 45 GPH fuel pump
Mallory Fuel Pressure Regulator
4 Dodge Neon SRT4 Stage III injectors
4 Stock 02 civic injectors
Custom Fuel rail with #4 braided stainless fuel lines to each SRT injector
All XRP Aluminum Fittings
3/8 inch; custom hard aluminum fuel feed line
Stock feed line converted to a return line
Turbonetics T3/60-1 ball bearing hybrid Turbo
ATP wastegate Stud kit
ATP wastegate blockoff plate
TiAL 50mm Blow off Valve
TiAL 44mm Wastegate (0.8 bar spring)
Custom 3 inch; downpipe
Custom 2.5 inch; aluminum intercooler piping
Greddy Emanage with Injector harness, Ignition harness, and greddy MAP sensor
Custom 2.5 inch; exhaust with a 31 inch; resonator and matrix muffler
ARP Head Studs
Ported vtec cylinder head
Custom Arias Pistons
Total Seal Gapless Rings
Crower Rods
modified stock crank
Darton Sleeves
Modified KMS D16 block guard (*thought it was an STR, but turned out it was a KMS replacement for the STR)
Honda Main Bearings
Clevite rod bearings
ARP rod bolts
Nippon Leakless Head Gasket
Custom fit Integra GSR Intake manifold with 8 injector bosses
Exedy Cerametallic sprung-hub 3-puck clutch
Exedy pressure plate
Custom short shifter
battery re-located to the rear
I told him no. Im going to be busy with Dan building the rest of my turbo kit.But it still drives great. The clutch seems to be breaking in nicely. It still chatters, but nowhere near as bad as before. I have about 130 miles on it now.
I am looking for about 15 psi daily once the car is completely tuned. But it should be fun.Here is a short list of some of the parts i am using on my car. I have more, i just cant remember them off the top of my head. Also, i have a TON of XRP fittings im not including in here.
ARP Head Studs
Crower Rods
Darton Sleeves
Honda Main Bearings
ARP rod bolts
Last edited by turboengnr; Mar 28, 2006 at 12:55 PM. Reason: Automerged Doublepost
DONT PANIC
As soon as i save up a bit more money, i will buy an E-cutout.
I dont want a loud car, so a large exhaust is out of the question. Plus i plan on driving this car when i have a kid, so i dont want it waking them up from a sleep (although my damn fuel pump is loud as ****!)
But the e-cutout will replace the full exhaust. Should work great.
e-cutouts are pretty cool... i saw an altima with one at a 909 meet a couple years ago...
we should dynomat your firewall to muffle the sound of your fuel pump...
i have an idea that also has to do with a daily driver fuel setup... I'll hit you up tonight if you're on AIM about it..
DONT PANIC
I could take a vid, but its nothing special. Sounds like a normal civic, with one hell of a fuel pump whine.
Dan, i wont be on AIM tonight. I am in class right now, and will be here for the next 3 hours. Its a Media Technology in American Society class.
But yea, lemme know about your idea for the fuel setup. But my fuel pump is actually located just underneath my shifter. I think dynamat may still help. But we can put it inside the car so i dont have to un-bolt the damn pump cuz its a pain in the ***.
Damn Mike. It sounds like quite a bit has gone on since I last checked these boards out. Hopefully I'll be buying a turbo kit for my new Z by this weekend or next (I'm gonna wait until I have over 3k miles on my car before install). Give me a call. I gotta check your setup out.
EDIT: That is pretty hot
DONT PANIC
Garrett..... Dan (Iamboo), Rob (oldschool homie from SF who left with me) and i are going to be building the rest of the turbo setup this weekend. You are more than welcome to come over.
I FINALLY got my payment through for my wideband today. So i wont have it til next week. So no boost until i get it. But it will still be on the car and functional.
Remember when i was telling you about my crew members APS TT 350z? Well he is about to upgrade to this SGP Racing long block...
Ultimate Long Block: $11,500 + $3500 Core - Good to 850+ Rwhp
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate / Billet Head
Crank balanced
Crank journals polished
*Darton MID Sleeves
*COMETIC Metal Head gaskets
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
* Custom SGP Racing / CP Pistons Up to 98mm Bore(8.5:1 or 11.5:1)
Ceramic coating on Piston skirts and tops
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*Tomei Upgraded Cams
*Ferrera 1mm Over Valve Train
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Valve Seats
New Nissan Head gaskets / Big Bore COMETIC Metal Gaskets
New Nissan Oil Pump
New Nissan Cam seals
Block redecked
Crank balanced
*Darton MID Sleeves
Pauter Rods
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
Heads redecked
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
DONT PANIC
lol. I am hoping for the 12 second club within a month and a half. And then within the next 6 months the 11 second club.
I think the members of the 11 second club will be Me and Andy within the first 6 months.
DONT PANIC
yea. I think you would need a little more than an M45 to do that though. Or are you running an M62? (im too lazy to look
Anyone who can produce a timeslip can join the 13 sec club or create any of the others.
)Anyone who can produce a timeslip can join the 13 sec club or create any of the others.
I Hunt Goats, Rams, And Mustangs.
I Actually belive its the MP62. on jacksons page its JR62 lol. But I should at least be in the 12 sec club, when i get a full tune and come down to Palmdale on the 8th. ill let yah know
lol
lol Registered!!
Block redecked
etc.
Block redecked
etc.
Ok, I'll hit you up on Saturday.
I hate your rich friend.
But you might want to tell him to send a PM to 350zDCalb over at
www.my350z.com
They're building Z motors and are supposed to be offering some really discounted prices. Their website isn't up yet but it's going to be:
www.builtzmotors.com
Originally Posted by MajinB
yea well turboengnr here is tellin me how poor he is over AIM. wtf is what i had to say. if you own a 13 second car then you are not poor. hahahahaha
Dude. He's married! He doesn't own a 13 second car. His wife does. She just let's him work on it.
DONT PANIC
^^ you know he is right....
But yea, if anyone wants to meet up at IDRC, i will be with team Controlled Inertia underneath a few Easy-Ups. Im the skinny white guy named Mike.
There are 2 of us skinny white guys named mike on the team, so you have a 50% chance that it will be me.
Just look for the easyups with the black twin turbocharged 350z, black T76 powered Supra, Blue GT35R stroked Celica GTS, Black STi, and others near it.
Drunken Master-7thgen Ninja
thats fvking sexy
