TSI with no FUEL UPGRADE
Old Mar 13, 2006
SleakCivic02's Avatar
SleakCivic02 should not be trustedSleakCivic02 should not be trusted
i bought a tsi t25 with no fuel option cuz i thought i could afford the emanage and injectors at the same time and now i am broke (tickets and damn police) what is the cheapest way to get some fuel upgrade that i can run my turbo at. i know apexi s-afc 2 is good but its like $275. that looks good but no big money in my pocket. help me out. thanks..... boosted with no go sux
Old Mar 13, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Yes, damn police pulling you over for doing stupid ****.
Cheapest way is to not put it in. Stock injectors can't push enough gas.
Old Mar 13, 2006
skipbarber's Avatar
just wait until you can buy the **** you need.
Old Mar 13, 2006
eye_see_you's Avatar
let the devil out
rsx injectors in place of stock and use e-manage or the apex controller is a low cost option
Old Mar 13, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Or looked into "For Sale" forums to buy TSI 2 injector controller.
I think someone was selling it few months back.
Old Mar 13, 2006
you guys really dont know the meaning of cheap. **** i am broke. good help you are... apexi is the way to go right now
Old Mar 13, 2006
Jeff's Avatar
Jeff is an unknown quantity at this point
I have a brand new sf fmu that has been sitting in my room for ever.
Old Mar 13, 2006
Jap-Euro Fusion
The meaning of cheap is don't put the turbo on. I'm really gonna laugh my *** off when you put it on without enough gas to run it and the whole thing blows.
Old Mar 13, 2006
dipset82's Avatar
dipset82 is an unknown quantity at this point
i know u probably expected to just buy the kit slap it on and then, have fun but it does'nt seem 2 work like that. I feel your pain i was kinda in the same position. But one of my boys told me i was rushing to get my car fixed up and i have'nt even had it two years yet. I would honestly say bro just to chill out wait until you have the right parts and then put it all on. Because if you take shortcuts you may blow your motor like boilermaker said, then you have no turbo no motor no nothing but headaches. Patience My Dear Friedn Patience!!!
Old Mar 13, 2006
let the devil out
boosting is not cheap for a N/A engine.. keep that in mind
Old Mar 13, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Exclamation
I bought GUNS sf fmu for from a member here almost a year ago, its been doing fine so far....
Old Mar 13, 2006
turboengnr's Avatar
DONT PANIC
Go ahead and run your stock injectors with just an SAFC II. That extra 10% pulsewidth increase on the stock injectors should supply you with enough fuel to run some boost. Just use a boost controller to turn your boost down. If you dont have a boost controller, just take the vaccum line off the wastegate actuator. Your car will only make as much boost as it can handle. If there isnt enough fuel, then it wont do it. Simple as that.
Ok, enough with the fairytales. Do it right and get a REAL engine management. SAFCII is crap. Stock injectors are crap. Work around those parameters and you should be fine.
Old Mar 13, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Simple as that, LOL!
Old Mar 13, 2006
so to drive the car under safe conditions i have to take off the hose off the wastegate. trust me i know i need a fuel upgrade but as i stated above i got a ticket that i need to pay off so my emanage and rsx injectors fell throught, i need to drive my car. i thought you guys could help. thanks for those you did, also getting few engine codes, one stationg the map sensor problem and my idel controll unit also..... any suggestions
Old Mar 13, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
dude....why don't you just listen to everyone...being the people that said get emanage&rsx injectors....you've been driving it stock so it's not that hard to wait
Old Mar 13, 2006
civic01vtec's Avatar
I would wait and save up money and do it right the first time.
Old Mar 13, 2006
i know, but i am with out a car now, i mean i need the car to get to work. i live like a mile away. trust me i want to do it right and make some good numbers but **** happens that you dont expect it to so you have to look other ideas. i guess i have to run it at low psi, but right now without the better fuel delivery i am having these problems, idel is at 600 rpm and some times the car shuts off. i can only rev it to 3500 rpm in 1st and 3000 rpm in 2nd so on. i know i am not getting fuel, i cant lower my boost without a boost controller. i guess i have to walk to work or something... buy a bike at walmart...whatever. plus i am not sure if i wired the black box correctly cuz i am getting a engine code p1505 which means map sensors detecting more preasure that expected. and a engine code p1219f which has to do with the idel... thanks guys
Old Mar 13, 2006
turboengnr's Avatar
DONT PANIC
you cant lower your boost.... period.
Take the rod off that connects the wastegate actuator to the internal flapper. This will prevent the turbo from spooling up. Then you can try to drive it easily. Im not saying it is safe, but definately better than running it any other way.
And get the damn correct parts right away. Dont waste money or time on an safc.
Old Mar 14, 2006
Havok2k1's Avatar
Wicked Pissah Admin
why don't you take the turbo stuff off and run OEM? That is the only way to solve your problem. The people above are not being a-holes, they are telling you the truth and trying to help you from killing your motor....
Old Mar 14, 2006
jackburton's Avatar
Something will break and then you will spend money fixing that, when you could be spending it on what you need. Is it really worth it?
Old Mar 14, 2006
ajhdragon's Avatar
7thgens official a$$hole
I got an SF FMU if you want to buy it. Works fine. Just reccommend tightening the lines and some new teflon tape on the threads. I took it off becasue i got E-Manage after i got a small leak.
Old Mar 14, 2006
C2i0v0i1C's Avatar
SuperMODrizd
it aint gunna happen.
here is how i see it.
1. you dont listen to us
2. it blows up
3. you make a thread telling us how it blew up and u want to know why.
4. i lock it bc we already told u the reason, you just didnt listen.
so....take it off. when u get the money do it right. half assing **** gets u in trouble 200% of the time
Old Mar 14, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
2. it blows up
wont be surpirsed...
You can take this any way you want. Never half a$$... Half a$$ing ALWAYS leads to more problems then your expecting. There is no halfway with boosting these motors. Its **** or get off the pot. There are realisticly only 2 options for you. Remove boost or BLOW ENGINE.
Old Mar 14, 2006
let the devil out
its the truth don't do it half way do it right one time and you will never regret it
Old Mar 14, 2006
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
Ur being ignorant just listen to the people who know what there doing they wouldnt tell u this sh*t for the hell of it. Damn
Old Mar 14, 2006
the ecu detects the too much presure with the map sensor and creates its own rev limit. so its safe, found that out today with mastertech.... $3000 worth of diagnostics is sweet, thanks for advice guys
Old Mar 14, 2006
Havok2k1's Avatar
Wicked Pissah Admin
LMAO
good luck. You'll need it.
I'm closing this.
Old Mar 14, 2006
C2i0v0i1C's Avatar
SuperMODrizd
the ECU doesnt create its own rev limit.
3000 bucks and u had no money in the begining of this thread
GritzNGravy
Aug 19, 2015 03:03 AM
henrytn
Aug 11, 2015 10:01 PM
swaff39
Aug 11, 2015 07:16 AM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
