alternatives for Missing Link
Old Feb 6, 2006
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Trying to read through all the posts now relating to Missing Link, but thought I'd start a new thread for more feedback.
What other options are there to keep the cel from showing up when there is positive pressure? I saw on one thread where dezod stated he could never make missing link work correctly so I'm trying to find other alternatives. The OBDII gets scanned down here my town so I want to try what I can to keep CEL's from showing up after I finish my turbo project.
Thanks.
Old Feb 6, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
E-manage is a less-ghetto way.
Some people make a series of check valves from fish tank valves to bleed boost off before it gets to the MAP sensor. Probably just as questionable as the missing link.
Old Feb 6, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
The missing link has worked for a few members.. just because dezod's one didnt doesn't meen that it won't work for you. If you plan on using an emanage it has a voltage clamp, which essentially does the same thing. There is also "splitsecond'', they make something along the same lines as the emanage's voltage clamp. The ML is working for me and I have hit been to 10 psi many times.. no CEL, nothing..
Old Feb 6, 2006
XSRCivic's Avatar
This is one of our previous boosted members "JWCardy" had to say about it.. SynapseEngineering..
Old Feb 6, 2006
PrecisnTec's Avatar
I just read a thread where voltage clamp was mentioned. I am using emanage. Would that be what the purple wire is for? The VML I think? You're supposed to cut it and connect it to the wire to the ecu and leave the one from the engine unconnected?
Old Feb 6, 2006
dezod's Avatar
7thgen Power Maker
LOL
It is not our check valve. It is made by Synapse Engineering.
It works fine, but IMO the E-Manage voltage clamp is far more superior.
Old Feb 6, 2006
XSRCivic's Avatar
^^ misunderstanding.. i meant to say that the one you were using ,which was SE's check valve didnt work for you. I am also using that same check valve. I agree on the voltage clamp being far more superior based on others' comments about it, not from personal experience, yet.
Old Feb 6, 2006
dezod's Avatar
7thgen Power Maker
Check valve worked for me, but required more tuning than the voltage clamp.
Old Feb 6, 2006
XSRCivic's Avatar
more tuning? care to elaborate some? would you say the check valve is more inconsistant than the VC?
Old Feb 6, 2006
dezod's Avatar
7thgen Power Maker
The ML gave us so many top end lean spots on the same tune versus the VC.
The ML I think clamps the voltage much sooner requiring more tuning not only for normal throttle response but for the boost as well.
The VC is a bit more controlled, and you can clamp the voltage at persay, 4.95V out of 5 leaving less tuning overall in comparison.
Old Feb 6, 2006
XSRCivic's Avatar
Understood.. good looking out man!
Old Feb 6, 2006
dezod's Avatar
7thgen Power Maker
No prob.
Old Feb 6, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
ML does great on mild psi. on my t25 at 6psi it worked great, but at 8-9psi it cant bleed boost fast enough, so I may/may not cel after a hard boosted run...It will dissapear soon after and car wont go into limp mode. I dont worry about it now, but I'm thinking about modifying ML to handle well under more psi than 9
juror
Suspension DIY
Jul 30, 2019 03:28 AM
WaryDriver
Aug 8, 2015 05:08 PM
jzhartman
22
Jul 23, 2015 10:42 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
