intercooler
intercooler
Anyone know which IC(or specs) that would be possible to fit in the 05 4dr lx bumper with no modification required to the bumper? I have looked numerous places but i can't find a definite answer and if anyone has specs can you please post them?
Thanks
Kev
Thanks
Kev
4 sounds pretty thick.
Only sure fire way, get in there with a measuring tape. Don't forget you've got a pipe to run too, and you'll most likely find yourself trimming some stuff to get that in there.
the thinner and shorter it is, the more likely it'll be since the bumper is widest in the center.
3 is as thin as they go.
you need to clear the bumper bar too. so my guess is you'll need ____x6x3
or so. usually ICs are sized by core, so add 4-7" onto that for the end tanks.
Go measure, and build a cardboard mockup. thats what I did, its the only way to get it the way you want it.
7thgen Power Maker
We have one that would fit that is awesome sized and pretty easy to work with. End tanks are on opposite sides.
Dimensions are: 7" h x 29" w x 3.5" D
It is a bar and plate design intercooler, not tube and fin (like 80% of the intercoolers out there). Far cheaper than Spearco or other bug name brands. We TIG weld the end tanks on, and weld 2 nuts in place on the top of each to aid in mounting it to the vehicle. (this pic does not have the nuts welded on yet)
We will have many of these in stock by early next week.
hey dezod have u test fitted this IC in the 4dr civics?....will this IC fit w/o modification to the bumper?...how much are u pricing this for?.....will there be a kit with charge pipes?...thanks
Kev
Kev
Kev
Kev
an intercooler and all the piping:
http://www.dezod.com/pd_dezod_motors...pipe_kit_w.cfm
or this one with just the piping:
http://www.dezod.com/pd_dezod_motors...r_pipe_kit.cfm
theres also one with a manifold, turbo, wastegate and downpipe:http://www.dezod.com/pd_dezod_motors...civic_0105.cfm
7thgen Power Maker
Originally Posted by jamie_civic
check out the website...theres all kinds of "semi turbo kits"
7thgen Power Maker
Kev
Kev
This is priced on our site for $425, however 7thgeners wanting to do custom turbo stuff, PM me for special pricing
Supramk3
Jun 11, 2015 11:13 AM
HondaGuru
Mar 2, 2003 05:14 PM
