custom supercharger
Old Jan 23, 2006
  #31
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
ever thought of cutting in to the fiire wall ? just a thought,
Old Jan 23, 2006
  #32
turboengnr's Avatar
DONT PANIC
anyone see the vortec kit for the civic si that has the torque shaft inside a tube that ran the supercharger? Basically it allows you to install the supercharger on the tranny side, but the torque shaft goes across and mounts in-line with the belts, and has a pulley on it.
i dont see why that couldnt work. Maybe you should buy a B series vortec kit and check that out. I think it would be much easier to fit in there than trying to get the whole supercharger shoved into such a small area.
Old Jan 23, 2006
  #33
turboengnr's Avatar
DONT PANIC
this.....
Old Jan 23, 2006
  #34
blouisgod's Avatar
Life Begins > 6800rpms
Originally Posted by turboengnr
this.....
yeah, just use the b16 or b18 IM
make it happen
Old Jan 23, 2006
  #35
turboengnr's Avatar
DONT PANIC
wouldnt even need to do that. Just a 90* bend from the aftercooler to the stock TB.
If you really have to, it is possible to swap the intake manifold fom a b series. I love my GSR manifold.
Old Jan 24, 2006
  #36
boricuachulo's Avatar
boricuachulo is an unknown quantity at this point
just got the spec. will post it soon
Old Jan 24, 2006
  #37
R1Style's Avatar
It doesn't look like the kit comes with the aftercooler.
But on a side note... I highly doubt you'll see in increase of 100hp on our D17. A B16A2 with a JRSC get's about 40hp to the wheels.
Remember... a supercharger uses power to make more power.
Old Jan 24, 2006
  #38
turboengnr's Avatar
DONT PANIC
the kit i posted a pic of comes with the aftercooler, its right in the picture.
Old Jan 24, 2006
  #39
info
Old Jan 24, 2006
  #40
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
At 10psi you will see double power with aftercooler.
Good table.
Old Jan 25, 2006
  #41
iamboo's Avatar
Retired - SoCal FI Mod
Good table.
the table is misleading... i think that when companies come out with these sort of diagrams, they should also disclose that not every engine will perform uniformly.
i think it's common sense that the sc with the aftercooler would produce higher numbers
Old Jan 25, 2006
  #42
PROCHARGER been around for some time now.
but you have a point every engine are not the
same. but for them being in business for many years
i belive the number. and i belive i will hit the
220hp mark with it. then add internal
(Engine kit..piston,cam..ect) to hit the 250hp or more.
of course it takes some tuning
Old Jan 25, 2006
  #43
I know it a bit misleading. Its impossible to prove otherwise. So I just agreed with it.
Old Jan 25, 2006
  #44
it will be proved in the near future by me
to see if it does that much power
love chargers no laging.
Old Jan 25, 2006
  #45
Way to go!
Old Jan 25, 2006
  #46
turboengnr's Avatar
DONT PANIC
actually, centrifical superchargers usually are not positive displacement blowers. That means that there is a lag until a certain RPM point.
But as long as you are above that RPM point, then you are correct, no lag whatsoever.
Old Jan 25, 2006
  #47
Eclectic's Avatar
Eclectic is an unknown quantity at this point
sweet! a supercharger for the 7thgen! just like other people said in this thread, it would be nice to have a stronger daily driver since i don't race
besides, i heard there's lots of maintenance with turbo. is there any like that for supercharging?
Old Jan 25, 2006
  #48
tfnaaf's Avatar
BLDNPSI Mod
What maintenance is that? I've changed my oil twice since ive installed mine. No other maintenance needed
Old Jan 25, 2006
  #49
Matulin407's Avatar
this makes me wanna wait until he starts charging!, or i can start by own Prjkt with the vortech B18c kit and try to get it modded to fit. Looking @ the Vortech system thre does not seem to be TOO much work involved to make that fit.
Old Jan 25, 2006
  #50
I wonder every time when hear "turbo - more maintanance"...
What does it mean - no one realy knows.
Well I changed oil and little missing link filter and that about it. I usualy chqck just regular things under the hood, but its like any other car.
Old Jan 26, 2006
  #51
since the charger am buying which is a c-1
has no oil line. you will have to change the chargers oil
just like in a engine. drain then fill every 6,000 miles.
that easy. belive me it will only take you like 5 min.
to do it. will show a pic how it looks soon.
Old Jan 26, 2006
  #52
Matulin407's Avatar
do u guys think this is possible? looking @ it does not seem to be hard @ all to make it work. Maybe just shorting the pulley shaft thing.
should i take a gamble?
with the vortech kit
Old Jan 26, 2006
  #53
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
as long as you understand the changes that have to be made to the vortech kit, then yes go for it and tell us the result
Old Jan 26, 2006
  #54
Matulin407's Avatar
i will wait, lemme just get turbo put on first lol. I would rather have a SC though, i hope this guy can make this happen.
Old Jan 26, 2006
  #55
well after some smart research. i will finally buy the
universal supercharger kit from "PROCHARGER"
in the next couple of weeks. i already talk to the guy
that going to fabricated for me. he's going to look me
out give me daliy dyno tune for $125!! not bad huh
$80 an hour for labor but will work with me. so am
see as a guess...$5,000 maybe $1000 more.
Old Jan 26, 2006
  #56
Cptn. Slow's Avatar
that's awesome man. I really hope that works and can't wait to see dyno sheets in the future
Old Jan 26, 2006
  #57
mikenam's Avatar
mikenam is an unknown quantity at this point
can' wait to see the results.
Old Jan 26, 2006
  #58
I may missed it somewhere, but what fuel system are you going to use with this set up?
Old Jan 26, 2006
  #59
the recommend one from "PROCHARGER"
will let you know the model soon
Old Jan 26, 2006
  #60
spudracer326's Avatar
spudracer326 is an unknown quantity at this point
seems kinda cool still a **** load of money though
