custom supercharger
Old Jan 26, 2006
  #61
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
<<<<interested in seeing how this turns out...
Old Jan 26, 2006
  #62
Havok2k1's Avatar
Wicked Pissah Admin
The procharger one is a FMU. Won't work on a returnless system as it comes, you'll need some fab work...
Good luck with it....
Old Jan 26, 2006
  #63
Havok2k1's Avatar
Wicked Pissah Admin
and the procharger kit is just and air to air IC, the vortech aftercooler is air to water.
What shop in Jersey is doing it? One of the top procharger tuners in the US is in Jersey, Larocca's shop...
Old Jan 26, 2006
  #64
cosmo's Avatar
cosmo is an unknown quantity at this point
Just swap in a R18
Old Jan 26, 2006
  #65
boricuachulo's Avatar
boricuachulo is an unknown quantity at this point
nope. i will keep my little 1.7 v-tec
Old Jan 27, 2006
  #66
i talk to them. then dont do hondas just mustang.
but hopfully will get the kit for 3,000
then 2,000 for other work
Old Jan 27, 2006
  #67
familycar's Avatar
as stated before the kit comes with a FMU and a FMU willnot work unless the fuel system is converted to a return system. but you can also fab a make shift return system that re route the return line form the fmu back to the rail
Old Jan 27, 2006
  #68
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
emanage with rsx-s injectors is better fuel option then FMU.
Can you optout from FMU?
Old Jan 27, 2006
  #69
familycar's Avatar
im sure you can but that is just even more money now. i wouldnt think it would be too smart to spend $6-7k on this project. the gains arent going to be as good as he thinks. maybe 40-50whp at most. that is a good increase in power probably about 50% but still when turbos can give that much power if not more for 1/2 the cost it doesnt make a lot of sense
Old Jan 27, 2006
  #70
familycar's Avatar
you will make more power with a t/c than a s/c becasue you dont get full boost until max rpm where as a t/c you get full boost by xx rpm(3500-4500)
Old Jan 28, 2006
  #71
every one has their opinion of course.
i know i will make alot of hourse power
especial a "PROCHARGER" tech doing it
Old Jan 28, 2006
  #72
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
Dont give him a reason not to do it. I want to see this thing.
Old Jan 28, 2006
  #73
AzNmiKex215's Avatar
2k1civic.com O. G.
isn't the power you make based off of the pulley used which in turns alters the PSI?
Old Jan 28, 2006
  #74
familycar's Avatar
yes it does but too large of a pulley will give you max psi at a lower rpm but then after that point the s/c is blowing hot air. centrifugal drivers are only good for a certain rpm. that is why you see more roots or screw type drivers in racing. you rarely ever see more than a 60% increase in power with our car that means max about 160whp with the basic system probably running about 10psi. i wouldnt expect anything more. if you do i will be impressed. so just get this done and impress me already and put my words back into my mouth. Good luck though!!
Old Jan 30, 2006
  #75
turboengnr's Avatar
DONT PANIC
huh??
If you change the pulley on a centrifugal, it will change the boost. And the reason you see roots type and twin-screws in drag racing is because of their efficiency. The twin-screw superchargers are extremely efficient. They are also able to compress the air far past what a centrifugal could.
But as for only a 60% increase, that is determined by #1. the blower, #2. the pulley setting, and #3. the tuning.
Look at it this way....
a centrifugal is nothing but a turbo thats run by a belt instead of exhaust gases. If you can do it with a turbo, you can do it with a supercharger.
Old Jan 30, 2006
  #76
familycar's Avatar
Originally Posted by turboengnr
huh??
that is exactly what i said just worded a different way. maybe i just didnt explain it clear enough
Old Feb 1, 2006
  #77
just got a good deal on the "PROCHARGER" from larroco's
3,000 with IC. will take pic's to show. now
to get the FMU..lol
Old Feb 1, 2006
  #78
familycar's Avatar
to get the FMU..lol
are you going to run a FMU with a makeshift return system or are you going a piggyback route. i would opt for the piggyback if i were you
Old Feb 1, 2006
  #79
mrDFWmechanic's Avatar
ditch the fmu !!
Old Feb 1, 2006
  #80
so i should piggy-back then?
Old Feb 1, 2006
  #81
familycar's Avatar
definately. for the money i would go with a greddy emanage and a set of rsx injectors. a fmu is just a band aid. especially fixed ratio FMU's. with a fixed ratio you are going to have a lean spot from when the unit detects boost until you recieve the higher fuel pressure. also you have a flat AFR. say you choose a 12:1 FMU its adding 12psi of fuel to 1 psi of boost. this causes your AFR to be a flat line rather than a fluxuating curve. you may not need as much fuel at lower boost pressures as you do at full boost. the piggyback unit will adjust your AFR accordingly and also give you adjustments to control the injector duty cycle and pulse width and also control iginition timming. these are important features when tunning a car. and the cost isnt but maybe a hundy or two different at most.
Old Feb 1, 2006
  #82
ok then i get the greddy emanage and the rsx injectors.
thanks for the tip
Old Feb 7, 2006
  #83
spudracer326's Avatar
spudracer326 is an unknown quantity at this point
you have any pictures yet. I kinda wanna see this thing
Old Feb 8, 2006
  #84
goodtimes's Avatar
ditto i want to see it to
Old Feb 8, 2006
  #85
v8eaterokv6's Avatar
i have a new home do u
bump for pics
Old Feb 11, 2006
  #86
iamboo's Avatar
Retired - SoCal FI Mod
i dunno if this is gonna work out...
i'm sure he'll be back with some news/progress on the sc..
Old Feb 12, 2006
  #87
It looks like some research work to be done, I'd think may be few weeks before we'll see any updates....hopefully sooner, then later
Old Feb 12, 2006
  #88
SLO REX's Avatar
250+ awhp Stage 2
Curiously waiting.
Old Feb 18, 2006
  #89
goodtimes's Avatar
any news yet
Old Feb 18, 2006
  #90
fieryhill's Avatar
fieryhill is an unknown quantity at this point
it's been like two weeks without any update...
