Type S Fuel Injectors
Old Jan 10, 2006
Civicman1988's Avatar
Will Type-S fuel injectors and rail fit on are civic the D17A2? Anyone know of an aftermarket one or even injectors?
Thanks any help is welcome
Old Jan 10, 2006
italy273's Avatar
italy273 is an unknown quantity at this point
Fuel Injectors
you can use RSX-S fuel injectors, you might need longer bolts and a spacer. You also need a way to control the fuel, or else you are going to be running rich. Nobody makes a fuel rail for the D17 yet.
This topic has been discussed many times...
Old Jan 10, 2006
turboengnr's Avatar
DONT PANIC
there are several different sets of injectors that fit.
RSX, Civic Si, SRT4, Base model WRX, etc...
they will all require you to take the stock studs out that hold the fuel rail, and replace them with longer bolts and some spacers (usually a bunch of washers).
But like he stated above, you will have to use something to control the fuel flow. Or else your car will be un-drivable.
Old Jan 10, 2006
Michalo187's Avatar
Abortion Survivor
I have used rsx type s and now am using srt-4 injectors both work good.
Old Jan 10, 2006
If i go with a civic si fuel rail i am i making anymore power?
Old Jan 10, 2006
Michalo187's Avatar
Abortion Survivor
no not even with bigger injectors unless ur turbo its a waste
Old Jan 10, 2006
ajhdragon's Avatar
7thgens official a$$hole
don't get bigger injectors unless your turbo, or else you will bog your engine down from runnig to rich. even on 10psi RSX-S injectors are big enough. i know a guy who is running 10psi on a T3 and SF fuel system with stock injectors for over a year. I think he is crazy but he does and runs 13's.
Old Jan 10, 2006
civic01vtec's Avatar
http://www.7thgencivic.com/forums/sh...tors+bolt+size
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
jody501
Jul 10, 2015 11:01 AM
