150 Shot On Stock D17
Old Jan 7, 2006
  #31
diskreet's Avatar
Originally Posted by drew22mader
"Your lucky that 100 shot NOS didn't blow the welds on the intake"
"Now me and the mad scientist have to rip apart the block and replace the piston rings you fried!" OWWWWWWWWWWWWW
Hmmmm i smell BS
Sorry, I farted.
But after it clears I think we may still smell something.
Old Jan 7, 2006
  #32
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
i dont think this guy has any idea what he is talking about. i know for a fact that if he is just running a 150 wet shot with everything else stock. he would not have a running car after a week. especially if he uses it 4 times a week. he probably just tells you that its a 150 shot but its probably actually just a 50 or 75
Old Jan 7, 2006
  #33
pon55's Avatar
Originally Posted by Curiouz_G
isnt anything above 150 shot suppose to be direct port instead of as a wet shot?
Any thing above 100 is a direct port to the brain! You can run 100 shot on a stock motor once in a while, many people have done it. Problem is its addictive, 4 times a week=no civic.
Old Jan 7, 2006
  #34
drew22mader's Avatar
There is gl@ss in my @SS...
He's a n00b, he also said in another post about getting the "Vtec Inside" sticker.
When you come into a forum stating fictional things, people will call BS, not because they just think it, but because they KNOW it can't be done. Its like me saying i'm gonna run 20 lbs of boost on my turbo with stock internals and no emanage, it can't be done!
Old Jan 7, 2006
  #35
ajhdragon's Avatar
7thgens official a$$hole
hmm 150 shot kinda hard to believe? im running a 50 shot with turbo, but tunned alot and only spray at the track. and check everything after i spray. but only sprayed 2 times with it. i guess you could run 150 shot if you are extremly well tunned and super cold plugs.
Old Jan 7, 2006
  #36
ZapThyCat's Avatar
ZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to behold
I always take posters like this with a grain of salt. It's not even worth discussing.
A noob can't approach a professional and tell him he's doing something wrong, the professional knows better. I'm not saying we're professionals... but we know this story doesn't jive. It's bs.
Old Jan 7, 2006
  #37
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
I just think that most people are calling BS because a 150 shot has ruined motors MUCH better and stronger than ours. A 150 shot is more than double the HP on a stock D17, so that's like someone coming over here and saying that they are running a stock D17 with 19+psi of boost on stock internals. You can do it once, just make sure that you get it on film. Nitrous also stresses the engine more than a turbo (instant hit). I just don't think that its happening.
Old Jan 7, 2006
  #38
andyman97's Avatar
Turbo Guru
Wow, I don't even know where to begin here. So, what's the reason he can't run a 150 shot? Is it because it's too much power for stock internals? Is that what everyone is saying?
Guess what, I'm running MORE than double the power my stock motor makes and I have never had problems from too much power. I am in the process of adding on more to get even better numbers. I will run a 12 second pass on a stock d17, however much power that takes. And the car will remain daily driven. So, if I can make 275-300 whp with turbo, why can't someone make 250 whp with nitrous?
Old Jan 7, 2006
  #39
diskreet's Avatar
How do you go from 13.8 to a 12 second run? hmm. You have 13.8 in your sig which is reasonable for a turbo setup, but 12 seconds, lets see some proof.
Old Jan 7, 2006
  #40
show0and2go's Avatar
show0and2go is an unknown quantity at this point
He's "in the process" of getting better numbers and he "will" run 12's. He doesnt have proof....yet.
Old Jan 7, 2006
  #41
diskreet's Avatar
I believe him but you dont jump in a thread where people are calling BS left and right and say something you CAN'T prove.
Old Jan 7, 2006
  #42
MajinB's Avatar
Drunken Master-7thgen Ninja
yes that is exactly right. since your running a turbo ill humor you and explain.
you are dyno'n around 250 like you stated. BUT you are doing it with
1. colder plugs
2. probably a NON stock clutch/pressure plate
3. a/f controller
4. turbo timer (maybe idk)
5. boost controller
6. probably different cams, 7.springs and 8.retainers
and a whole bunch of other ****.
and if you think our motor can handle 2x the stock hp on stock stuff then i demand you send me your turbo and nitrous kit so i could use it for better purposes
Old Jan 7, 2006
  #43
Havok2k1's Avatar
Wicked Pissah Admin
I'm not letting this go any longer. If he has some proof, then post it.
Misfit2613
Jul 30, 2015 09:49 AM
cizsak
Jul 21, 2015 03:39 PM
NoobyKid
Jul 13, 2015 07:53 AM
