Another sneak peak ***NEW UPDATE WITH PICS ON PAGE 7***
Old Feb 13, 2006
  #91
turboengnr's Avatar
DONT PANIC
just wait until i get the car bra i ordered.
Old Feb 15, 2006
  #92
kcm's Avatar
kcm
kcm is an unknown quantity at this point
get spinner hubcaps and tell people the spinning of it lessen the amount of force needed to make the tires move... that would be so awesome on a sleeper when running it on the street
Old Feb 24, 2006
  #93
familycar's Avatar
any updates
Old Feb 24, 2006
  #94
PunkingCivic's Avatar
I need TP for my bunghole
Old Feb 25, 2006
  #95
turboengnr's Avatar
DONT PANIC
yes. there are updates. How did you know?
Just picked this up TODAY!
Old Feb 25, 2006
  #96
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Okay one question.. why do you have sleeves and a block gaurd? I thought part of the purpous of sleeving was to reinforce the cylinder walls?
Old Feb 25, 2006
  #97
turboengnr's Avatar
DONT PANIC
darton cannot make the MID sleeves for our car due to a water passage at the bottom of the coolant jacket. So even though it is sleeved, it is still a fee-standing open deck sleeve.
The problem with that is when you start making a ton of power, the cylinders walk (rock back and forth). This can cause them to crack and break off at the bottom. When that happens, say good bye to all your good work.
The block guard is just going to keep the sleeves centered. It will not allow them to walk.
I have been to Dartons shop. Talked with the guys in person (who are all awesome and i recommend them to everyone). They told me that with just the sleeves, they would not recommend more than 15 psi. With the sleeves + blockguard, it is safe for 40+ psi.
Old Feb 25, 2006
  #98
Michalo187's Avatar
Abortion Survivor
Dam everything looks good mike. I can't wait until your done.
Old Feb 25, 2006
  #99
turboengnr's Avatar
DONT PANIC
Thank you!
I cant wait either. I started bolting on stuff as soon as i got it home. I was just soo damn excited.
I paid for all of this **** last march. So i have been waiting patiently.
Old Feb 25, 2006
  #100
Well instead of a block gaurd you should have looked in to block posting? http://www.homemadeturbo.com/tech_pr...block_posting/
Old Feb 25, 2006
  #101
turboengnr's Avatar
DONT PANIC
i dont believe in posting. I think it is a poor mans version. All of the force of the cylinder walk is focused on that one small area when you are using the posting method.
When you use a block guard, it is not focused on any one space. it is disbursed through the entire block guard.
block posting is greatly disputed throughout the automotive performance industry. Some people like it, others dont. I just happen to be one who doesnt. So lets not turn this into a war about that.
Old Feb 25, 2006
  #102
turboengnr's Avatar
DONT PANIC
oh yea. I did not have to notch the cylinder walls with my rods. They cleared fine
Old Feb 25, 2006
  #103
Michalo187's Avatar
Abortion Survivor
^^^^ Thats badass.
Old Feb 25, 2006
  #104
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
hella nice mane!
Old Feb 25, 2006
  #105
blouisgod's Avatar
Life Begins > 6800rpms
damn man, props to you for building the engine up even with one arm
Old Feb 25, 2006
  #106
drew22mader's Avatar
There is gl@ss in my @SS...
Yea no kidding! Make sure you take your wife out for dinner for all her help too! Lookin good man.
Old Feb 25, 2006
  #107
jhonsok's Avatar
The blackbeauty ES1.
sweeet....
Old Feb 25, 2006
  #108
Civicman1988's Avatar
thats bad *** looks hot cant wait to see how it runs. let us know
Old Feb 25, 2006
  #109
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Which blockguard are you going to go with.
Old Feb 25, 2006
  #110
turboengnr's Avatar
DONT PANIC
i am using an STR D16 block guard. Once you modify it, it works fine.
But yea, heather is learning a lot about motors right now.
Old Feb 25, 2006
  #111
turboengnr's Avatar
DONT PANIC
Did a little more work today..............
Old Feb 25, 2006
  #112
mrDFWmechanic's Avatar
can withstand 40psi holy crap batman
Old Feb 25, 2006
  #113
Michalo187's Avatar
Abortion Survivor
Is that how low the block guard should be? Mine is barely in there
Old Feb 26, 2006
  #114
turboengnr's Avatar
DONT PANIC
you know how people are worried that the block guards cause hot spots because they only have small holes for the coolant to pass through?
Well, if you have it at the very top of the cylinder, that is correct. You only have a few tiny holes for the coolant to flow through. So some people enlarge them. And that works, but you still have less coolant flow because you are limiting the coolant to the ports on the head.
But when you install the block guard 3/8" of an inch down, you have ALL of those little holes feeding the ports on the head, not just one or two holes. Get what i mean? By creating a gap, there is a much larger space for the water to flow into the head. Think of it like the plenum space on your intake manifold.
I would not recommend installing the block guard down this low on the stock motor. The point of a block guard (besided eliminating cylinder walk) is to reinforce the tops of the cylinders. When you start making tons of power, the top of the cylinder wall will break because that is where the bulk of the combustion takes place, and that is where the largest pressure spikes are.
But when your motor has sleeves like mine where the cylinder thickness is more than 3 times the stock one, you dont have to worry about that.
Old Feb 26, 2006
  #115
Michalo187's Avatar
Abortion Survivor
Ok thats good to know.
Old Feb 26, 2006
  #116
02blackcivic's Avatar
02blackcivic is an unknown quantity at this point
nice, cant wait til its done
Old Feb 26, 2006
  #117
turboengnr's Avatar
DONT PANIC
i am still shooting for April 8th. My goal is to compete at the IDRC nationals at LACR on april 8th.
Old Feb 26, 2006
  #118
andyman97's Avatar
Turbo Guru
I dono man, I hear what you're saying about placing it lower, but I'm not sure that will cool the head efficiently. I mean, yeah, there will be parts around the combustion chamber that won't receive much coolant if its placed at the top of the cylinders but those holes are small. Your coolant flow is still going to be restricted and not free flowing. The hot spots are usually not only on the head but around the cylinders, as well, causing them to warp. I'd be weary about it. But everything looks great man. What rods did you end up going with?
Old Feb 26, 2006
  #119
turboengnr's Avatar
DONT PANIC
the area of all of those small holes adds up to be more than the area of the ports on the head. So it should still cool rather well. I did make sure of that.
I am using crower rods.
Old Mar 19, 2006
  #120
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
pure sickness.....props for that fabbing man i love it!
