tapping into fuel line for nitrous
Old Dec 1, 2005
speedster's Avatar
speedster is an unknown quantity at this point
How did you guys go about this? It just doesn't look to me that a regular t-fitting adapter will work because our fuel lines are hard plastic. I don't see how the barbed fitting will go into the line because the hard plastic won't stretch. I just want to make sure I know what I'm doing before I cut my line.
Old Dec 1, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
What kit do you have?
Old Dec 1, 2005
speedster's Avatar
It's the NOS brand. It's the powerfogger universal wet 4 &6 cylinder kit, I believe. I got it used from a guy on here in the classified section.
Old Dec 1, 2005
scansel912's Avatar
Well I assume the T-fitting for the fuel line is similar to mine. In that case, it was a bitch to get on and get it to fit right. I think it took me about 7 trys to get it without leaking i think. I finally got so pissed off I just lubed the T-fitting with gas, and just pushed that line on there as far as it could go. I does work but you just have to have patience and muscle it on there.
Old Dec 1, 2005
v8eaterokv6's Avatar
i have a new home do u
the fuel lines arnt hard plastic they are regular rubber lines
Old Dec 1, 2005
speedster's Avatar
Are you sure. My line from the firewall to the injectors is a formed line. It says on the line "do not kink". That suggests to me that it's hard plastic. Can one of you guys post a pic of this connection. I would appreciate it.
Old Dec 1, 2005
djmota's Avatar
Well first let me say DO NOT CUT THE STOCK LINE. its a waste. go to a auto parts store buy some good quality fuel injection gas hose (about 3-4 feet) and 4 good quality fuel injection hose clamps. remove your stock line by undoing the clips and slip the hose over the hard lines and splice that. Now if you want to take your kit off you don't have to go buy a new 30 dollar stock fuel line.
Old Dec 1, 2005
scansel912's Avatar
The fuel lines are a hard plastic tube covered with rubber tubing.
Yeah try doing what DJmota said. I wish I would have done that last year, but Oh well.
Old Dec 1, 2005
speedster's Avatar
Ok thanks for the info.
Kyles24
Jul 16, 2015 10:14 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Kyles24
Jul 12, 2015 09:15 PM
