Turbo project detail engine pics 44k
Old Nov 28, 2005
  #31
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
Very nice setup. Once your monitor is up, you cant see those gauges though....
Old Nov 28, 2005
  #32
AlienX's Avatar
AlienX will become famous soon enough
Originally Posted by Spoolin
isn't 1 bar = 14.7 psi...
ya!!! isn't it???
1 bar = 14.5037738 pounds per square inch
Old Nov 28, 2005
  #33
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
I stand corrected.
Old Nov 28, 2005
  #34
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Why is the "Custom return fuel system with 1L. reservoir" needed with your set up? What purpose does it serve?
Old Nov 28, 2005
  #35
mxcivic's Avatar
mxcivic is an unknown quantity at this point
just beuty ....
Old Nov 28, 2005
  #36
02civic_rida's Avatar
if i remember him telling me correctly its so that theres always fuel ready.
Old Nov 28, 2005
  #37
supermex's Avatar
Well:
It has to do with the fuel outlet from the pump assembly in our tanks:
the outlet is very narrow, so, even if you have a bigger pump and a return system with big fuel lines installed, there is only so much fuel coming out of the outlet.
Acts as a bottle neck.
The fuel flow will only improve if you install a fuel cell on your trunk and bypass the stock tank and fuel lines.
In my case, I installed a return line and intank pump.
The only difference is that I installed a reservoir that will filled up from the intank pump than,with the help of an inline pump the fuel is pushed into the fuel rail, then, to the fuel regulator, then back to the reservoir that, if it gets to overfilled, the fuel goes back to the main tank via fuel return line.
So, I never get lean even during boost spikes cause I get as much fuel as I will ever need under any condition.
Old Nov 28, 2005
  #38
iamboo's Avatar
Retired - SoCal FI Mod
Originally Posted by Supermex
16psi
ehhh... 1 bar is a unit that expresses 1 atmosphere of pressure... according to my science text book, 1 bar of pressure = 14.5 psi
which means that you are running over 1 bar at 16psi or 1.103 bar
you're riding on the coat tails of barney... he made over 300 whp and ran low 12 second 1/4 mile times... almost there.. hehehe...
GOOD **** THO!!!
Old Nov 28, 2005
  #39
andyman97's Avatar
Turbo Guru
GOOD **** THO!!!
On a d17? Link? I hadn't heard that, the best I'd seen was 245whp.
Old Nov 28, 2005
  #40
ShoelessEX's Avatar
The wheel is turning...but the hamster is dead
ShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to all
Originally Posted by AlienX
Yes it is...and those numbers at 14.5 psi isn't all that great
Old Nov 28, 2005
  #41
SODJAZERO's Avatar
Well:
Thanks for that info man! I kinda figured that, but i wasnt sure about it.
Old Nov 28, 2005
  #42
iamboo's Avatar
http://www.7thgencivic.com/forums/sh...&postcount=23:)
Old Nov 28, 2005
  #43
mikenam's Avatar
mikenam is an unknown quantity at this point
one of your gauges don't work. don't really like the orange interior but thats just my taste. crazy numbers. seems like the ems made a huge difference. nice work.
Old Nov 29, 2005
  #44
supermex's Avatar
I know Phil (Barney) personaly and he didn't hit does #'s
He tried everything an threw money at that car.
Threre wasn't a computer available at the time to support all that power and not blowing something.
He tried lot's of stuff on his car but it could never got it to run right and it ended up parking the car on the garage.
That's the reason I'm not even trying it like that.
I radder be conservative and raise the power gradualy and still be able to drive the car to the store or go to the movies in it with no problem.
Old Nov 29, 2005
  #45
drunkenmagnum's Avatar
did he ever post pics?
Old Nov 29, 2005
  #46
supermex's Avatar
You are right is not that great but I'm protecting the engine and it leaves a lot of room for improvement.
Old Nov 29, 2005
  #47
thats double my current psi and i only make 180hp......so that is a lot of boost on a d17 that can be daily driven. again awsome car!
Old Nov 29, 2005
  #48
yourinmyw0rld's Avatar
That could be fix with EMS
S.Klinck
Feb 10, 2016 02:19 PM
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
cloudguy
Apr 28, 2015 05:02 AM
ImmortalEX
Nov 8, 2001 09:52 PM
