Help E-Manage Install Problem
Old Nov 21, 2005
hydroflare's Avatar
hydroflare is an unknown quantity at this point
I just installed a greddy emanage to my 04 civic ex. I have checked my wiring 5 times. All wiring has connection and has been checked with multimeter. I have the main harness, vtec, harness, and injector harness.
The car starts up just fine then couple seconds later I get a check engine light. I can't check the code cause I dont have the tool. I can smell the fuel like its running really rich. The emanage is set to stock civic configurations. Does anybody know if theres some special wiring or what?
Here are the wires connected:
Emanage ECU
White(map) A19-Green w/red to map
Yellow(vtec out) B15-Green w/yellow to vtec solenoid
Light Blue(vtec in) B15-Green w/yellow to ecu
Purple(VTM Out) B9-Vtec Pressure switch to ecu
Green(Map Out) A19-Green w/red to ecu
Brown(rpm) E26- tap to Engine Speed pulse
Black(ground) A5-tap to Power Ground
Red(12v) A3-tap to Power Source
Left bottom(injector Ground) A5-tap to Power Ground
Pin 1(Injector 4) B2-yellow tap Injector 4
Pin 2(injector 3) B3-Blue tap Injector 3
Pin 3(injector 2) B4-Red tap Injector 2
Pin 4(injector 1) B5-brown tap Injector 1
all wiring was soldered.
Need help please.
Old Nov 21, 2005
andyman97's Avatar
Turbo Guru
I don't see the tps signal wire in there.
Also, I can't tell you what to check if you don't know what the CEL is for......
Old Nov 21, 2005
tfnaaf's Avatar
BLDNPSI Mod
Emanage ECU
Need help please.
check the external dials to make sure they are zeroed? but other than that get a scanner
Old Nov 21, 2005
hydroflare's Avatar
all the dials are set to zero already. on the emanage the injector size are set to 240cc. is that the correct stock injector size? after the check engine light is on the car runs really rich at 11.9 on my apexi auto timer. also the tps sensor is hooked up. the tps and rpm responds to the emanage in real time. im going to go pick a scan tool and check the code later.
Old Nov 21, 2005
hydroflare's Avatar
the check engine code is the vtec oil pressure circuit switch high.
code P2647. i notice on the emanage ultimate that the vtec oil pressure switch isnt connected on the greddy diagram. do you guys know if that applies to the regular emanage? or do you think that its hooked up to the wrong spot?
Old Nov 21, 2005
TheSmuggler's Avatar
I think the general rule of thumb is to not change vtec so don't connect it to the emanage
Old Nov 21, 2005
hydroflare's Avatar
i will agree with you smuggler. the wiring and connections are right on the emanage to the vtec wires, but it just does not work for me. so forget the vtec controller settings. atleast i can control the fuel for my turbo now. going to install my turbo soon.
Old Nov 21, 2005
honestly, adjusting vtec always results in power loss anyway.did you read the huge thread about this?
Old Nov 22, 2005
dezod's Avatar
7thgen Power Maker
Are you running RSX injectors? Your not giving all of the info here.......something is not right.
Old Nov 22, 2005
hydroflare's Avatar
i have rsx injectors but i have not installed them yet. the whole engine is stock right now. do you have the link on the vtec forum?
Old Nov 22, 2005
hydroflare's Avatar
do you guys know the stock d17 injector size?
Old Nov 23, 2005
http://www.7thgencivic.com/forums/sh...d.php?t=186443
Old Nov 23, 2005
240cc
Old Nov 23, 2005
dezod's Avatar
7thgen Power Maker
DO not touch the injector correction factor if you do not have the RSX injectors installed and VTEC switch over on the D17, DO NOT TOUCH EITHER.
Old Nov 23, 2005
oh okay so the vtec was decided that we can't adjust it with emanage?
Old Nov 23, 2005
skipbarber's Avatar
are you sure you have the vtec input and output wires hooked up in the right directions? I remember hearing that the instructions are poorly translated on that part and that they are supposed to be switched around.
Old Nov 23, 2005
hydroflare's Avatar
yeah the vtec is installed correctly which is the way the emanage instructions are layed out. this is my second time installing emanage on a car. never had a problem the first time. it was the vtec pressure switch that gave me a check engine light though.
Old Nov 23, 2005
maybe the vtec just doesn't work right with emanage.
Old Nov 25, 2005
andyman97's Avatar
Turbo Guru
There are people that have gotten vtec to work with emanage. Are you using the blue?
Just make sure your jumper settings are right.
Old Nov 29, 2005
hydroflare's Avatar
the vtec wiring is right cause i checked it like 5 times. the check engine code says that the vtec pressure switch voltage is high. maybe there is something different about the vtec on the 2004 model. i noticed that my car is listed as D17A2 1.7 16V SOHC VTEC-II PGM-FI . seems like a different vtec or something. I tested my car with 2 emanage systems and it did the same thing.
4 banger
Jun 5, 2015 01:44 AM
beveragemp
May 25, 2015 07:11 PM
Youshoe
May 22, 2015 09:36 PM
PimpBot5000
Nov 26, 2001 07:15 PM
Flatlander
Nov 16, 2001 05:38 PM
