spring psi on SF kit?
Old Nov 3, 2005
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
anyone know what psi the spring is set at on the SF kit?...its the super 60.
Old Nov 3, 2005
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
5.5?
Old Nov 3, 2005
turboengnr's Avatar
DONT PANIC
it varies. They are anywhere between 4 and 6 psi.
Old Nov 3, 2005
Michalo187's Avatar
Abortion Survivor
mine was at 6
Old Nov 4, 2005
civic01vtec's Avatar
Mine is around 5
Old Nov 4, 2005
meseetree's Avatar
meseetree is on a distinguished road
mine was 4.5 but not a super 60
Old Nov 4, 2005
alright thanx, just making sure it wasnt 8 or anything high...i need to drive it to the shop to get my fmu and injectors installed. i wont go into boost i guess
Old Nov 4, 2005
meseetree's Avatar
civic01vtec is running stock injectors on 15 psi I don't think you will have a problem.
Old Nov 4, 2005
ya but im sure he has some type of fuel system upgrade??
Old Nov 4, 2005
turboengnr's Avatar
DONT PANIC
dont drive it without a fuel system. you will just break it.
you will go "ok, ill drive it but wont go into boost".
then you will drive it, and it will accidentally hit 1 psi.
"wow, that felt good. But it didnt feel like it was breaking my motor. Maybe my car is special and i dont need a fuel system"
So you keep driving it, making 3-4 psi.
"man, my turbo runs good. But whats all that white smoke behind me and why is my car always overheating? Whats this white stuff that sprayed all over the engine bay?"
Several people have done it. It is just plain STUPID to even think about driving it without a fuel system.
The fuel system (especially the SF fuel system) is THE EASIEST part of the entire install. So if you can install the bolt on ****, then you can install the fuel system.
Old Nov 4, 2005
not quite that much
i run 8-10 daily.........i have hit 12-13 a few times and it was great.
Anyways, turboengnr is right, don't drive your car without a fuel system. You can disconnect the wastegate actuator rod and run 0 boost.
Old Nov 5, 2005
well if i drive under 3k rpm then it doesnt matter, the place isnt far away.
Old Nov 5, 2005
turboengnr's Avatar
DONT PANIC
it still matters. It can make boost before that. Dont think that 3000 rpm is the magic number.
Why cant you install the fuel system yourself?
Old Nov 7, 2005
well i can but i need help with the relay that comes with the newere(all silver) sf fmu....
i know you attach the nipple to a t fitting on the vacuum line, and cut the fuel line in the middle...the one attached to the firewall goes to the in, the one still attached to the fuel rail goes on the out. but then theres the wire that goes to the fuel pump, is that connected to the fmu?(theres place for 2 wires at the end of the fmu, im guessing one is the wire from the relay, and one goes to ground?)
anyways i really need some info if you got any
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
