Buyin a turbo kit
Old Nov 1, 2005
Firecracka05's Avatar
Firecracka05 is an unknown quantity at this point
Buyin a turbo kit
Fits any D16 -series motor
MANIFOLD INFO FOR D SERIES
FITS ALL D16 BLOCKS
1988-2000
I have a 2005 will this fit on my car ?
Old Nov 1, 2005
j-jolly's Avatar
j-jolly is an unknown quantity at this point
no, the mani would not fit up right we have d17 not d16
Old Nov 1, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Calling for member aznboysrfr and his picture from thread "k20a3 vs. d17 weight" !!!
aznboysrfr, come over here your noob help needed!
Old Nov 1, 2005
can i buy the manifold for my car like buy the obx manifold for my car an use the rest of the turbo kit ?
Old Nov 1, 2005
Sum1 please help
I bought a turbo kit for a d16 cud i jus buy the manifold for my d17 an use the rest of the d16 kit ?
Old Nov 1, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
you will probably only be able to use the turbo if you get the correct D17 manifold. Some of the charge pipes probably can be used, but you will hve to rig up your own pipe route. The IC probably can be used bit will also require a custome pipe routing.
You will also need a downpipe.
You will also need fuel management: Most likely Emanage with RSX injectors.
Old Nov 1, 2005
i mean wat about the turbo an stuff ? the waste gate an all that ?
Old Nov 2, 2005
iamboo's Avatar
Retired - SoCal FI Mod
FITS ALL D16 BLOCKS
1988-2000
Here's a clue why it won't fit... good rule of thumb.. don't buy turbo kits off ebay...
locked again....
READ THE TURBO FAQ!
http://www.7thgencivic.com/forums/fa...#faq_turbo_faq
HondaGuy7
Feb 22, 2016 01:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
beanhead
Sep 24, 2015 12:04 PM
