Dezod Catless Mid-pipe (replaces cat-ed EX pipe on our turbo system)
Old Oct 5, 2005
dezod's Avatar
7thgen Power Maker
Many people wanted to see pics...........here it is.
This mates to our shorty downpipe on our turbo system.
Old Oct 5, 2005
skipbarber's Avatar
and that bolts up to any EX cat-back exhaust system?
Old Oct 5, 2005
dezod's Avatar
7thgen Power Maker
It might, but it will bottle neck down immediately because this is 2.5". Most of the aftermarket production pieces are only 2.25"
Old Oct 5, 2005
Michalo187's Avatar
Abortion Survivor
whats the price? It only works for your turbo kit
Old Oct 5, 2005
dezod's Avatar
7thgen Power Maker
Correct. $200 sold seperatly. $155 with the kit on the core package. Included with the VP.
Old Oct 5, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
how about the 02 sensor bung. if I remember correctly, the ex 02 sensors are on the cat pipe instead of the header. does this pipe have 02 sensors in it?
Old Oct 5, 2005
dezod's Avatar
7thgen Power Maker
1 bung in it. The other bung is on the shorty downpipe.
Old Oct 5, 2005
ritalin's Avatar
ritalin has a little shameless behaviour in the past
Is 2.5 as big as you can go with the space available?
Old Oct 5, 2005
Alex1's Avatar
Is there a bolt that comes that you can seal that bung with if you have an LX or DX?
Old Oct 5, 2005
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
will this work with the SF kit?
Old Oct 5, 2005
im stock now! T.T
i could imaging the 02 bung fitting properly near the end of the pipe but wont it throw a cel? like other catless down pipes?
Old Oct 5, 2005
dezod's Avatar
7thgen Power Maker
Might be able to go 3" but it will be real tight.
A plug? No it is not supplied. This can be gotten from a local parts store in your area for approx $6.
Probably not.
Correct it will throw a CEL. You would probably need to run an O2 Sim.
Old Oct 5, 2005
turboengnr's Avatar
DONT PANIC
would this hook up to a stock ex header?
Because if it would, it would work for all the guys out there with an SF kit.
Old Oct 5, 2005
dezod's Avatar
7thgen Power Maker
Yeah I know, but it will not.
Old Oct 6, 2005
dezod's Avatar
7thgen Power Maker
Here are some pics of this pipe used in conjunction with our assembly.
ID:	61024   Click image for larger version
cloudguy
Apr 28, 2015 05:02 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
thesushiboy
Apr 12, 2015 02:54 AM
DriftR
Aug 23, 2005 03:57 PM
dxb31847
Nov 4, 2001 11:54 AM
