wondering how to get more fuel with a FMU
Old Sep 15, 2005
black01civic's Avatar
From: Mukwonago, Wisconsin....around the Milwaukee area
black01civic is an unknown quantity at this point
Question wondering how to get more fuel with a FMU
wondering if anyone can help me out.....i purchased a turbo setup for my 01 ex however it came with no fmu..... i purchased a Blox fmu, however as you already know there is no return line in the system to hook it up to...talked to a couple of shops and they said that i have to put in a "T" and hook it up to another return line.......???? not quite sure what they meant...just wondering if anyone can help..either with a web site...or more info..thanks
Old Sep 15, 2005
Havok2k1's Avatar
Wicked Pissah Admin
1. wrong forum
2. Search for the SF FMU and it will show you how to do it. (it's not that easy)
Old Sep 15, 2005
where do i search for it???
Old Sep 15, 2005
turboengnr's Avatar
DONT PANIC
hold on a second, i will draw you a picture of what you have to do
Old Sep 15, 2005
tfnaaf's Avatar
BLDNPSI Mod
Old Sep 15, 2005
turboengnr's Avatar
DONT PANIC
Here
Name:	Rising rate regulator for Non-return line cars.JPG
Old Sep 16, 2005
turboengnr's Avatar
DONT PANIC
basically, you just install an inline fuel pump as you would on a return line car. You then add a Brass T before and after the pump. You then run a line from the T After the pump, into an adjustable fuel pressure regulator. Then out of the Regulator into the FMU. Then out of that into the check valve. Then out of the valve into the T before the pump.
There you have it. a DIY SF fuel system.
Looks a lot harder when its all compacted into that little unit, huh?
If somebody wants to drive out here with all the parts, i will do all the routing and what not. Basically you will just have to do the electrical. Then i can write a DIY on it.
Old Sep 16, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
so u can up the fuel on an sf fmu with a fuel pressure regulator? I didnt know the sf fmu could be adjusted for more fuel at higher boost, is this possible?
Old Sep 16, 2005
turboengnr's Avatar
DONT PANIC
nope. The pressure regulator is just to set the base pressure.
Without the pressure regulator, it would take ~5 psi of boost before the kit gave you any fuel.
Old Sep 18, 2005
Libby's Avatar
Libby is an unknown quantity at this point
so in order to run a fmu and inline pump you would need a fuel pressure regulator? or no. if not how would u install a fmu and inline with out a reg or not thats not possible.
Old Sep 19, 2005
turboengnr's Avatar
DONT PANIC
look at the picture. that is how you have to do it. There is no other way (other than coverting to a return style fuel system).
Old Sep 19, 2005
Libby's Avatar
oka if i get a fuel pressure reg. what pressure should it be set at and what kind of reg like name brand wise? any kind of reg would be oka?
Old Sep 19, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
What does the fpr need to be set too?
Old Sep 19, 2005
turboengnr's Avatar
DONT PANIC
needs to be between 45-50 psi
Old Nov 25, 2005
Donggie's Avatar
Donggie is an unknown quantity at this point
If a boost referencing fuel pressure regulator is used in this scenario, will the fmu still be necessary?
Old Nov 26, 2005
Havok2k1's Avatar
Wicked Pissah Admin
yes. FP won't rise enough to make an impact to your fuel delivery.
Old Nov 26, 2005
Donggie's Avatar
Hey thanks for the answer. That makes sense. I appreciate your help.
Old Jan 30, 2006
kickoo's Avatar
kickoo is an unknown quantity at this point
so is it needed to have a INLINE FUEL PUMP not just an FMU? And another thing where can I find the adapter hardware to tap these fule lines into the FMU?
Old Jan 31, 2006
SODJAZERO's Avatar
local hardware store, ie ace, lowes, home depot.. .
Old Jan 31, 2006
kickoo's Avatar
any specific type metal or grade?
Cyborg Ninja
20
Jul 11, 2022 03:44 PM
DerbyDad03
Exterior
May 16, 2021 10:07 AM
Edwin__em1
Jun 13, 2015 11:57 AM
mrohitredd
May 28, 2015 10:03 AM
BootyDo
May 7, 2015 04:46 PM
