New turbo problem please help again
Ok I figured out were the oil was leaking from now I have the turbo on. The only problem is there is no boost!!! I have a tial wastegate, with it open on the part that doesn't attach to the manifold. Someone I know said that they think its the wastegate being open like that but Im not for sure if any of you can give me some help that would give me a place to start looking for the problem. I haven't messed with my boost controller yet because it was to late and I was tired do you think it could be set low or anything like that any help would be appreciated thanks.
Originally Posted by 042dr
imo the wastegate shouldn't make that much of a difference in boost w/out the dump tube but i'm not sure. I think you need some type of boost controller.
DONT PANIC
check your intercooler pipes.
does your engine sound very loud while at idle, almost like you have no exhaust? If you can hear exhaust coming out of the wastegate, then that may be your problem.
When you are new to turbos, the most common thing that happens is you leave an intercooler pipe loose somewhere. If 1 intercooler pipe is simply loose, you wont have ANY boost. Double check all your pipes.
No boost at anywhere
Originally Posted by tfnaaf
I also assume you mean while driving around? or in neutral? Most turbos WONT build psi in park/neutral
That is the first thing i thought about.
check your lines, running from the waste gate to the compressor housing.
Make sure there not plugged up. Also dont know what boost controller you have make sure you installed the one way filter the right way.
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 8, 2015 11:16 AM
