Turbo install gone bad need help
Old Aug 22, 2005
cbaer543's Avatar
cbaer543 is an unknown quantity at this point
Ok I got everything put on for the most part last night. The only things is we couldn't figure out where 3 of the nuts went for the studs on the oil pan. So I started the car to see if anything would go wrong and all the oil came out when I started the car. It came from the back of the oil pan where the oil drain plug is. Would thoughs 3 studs w/o nuts be the cause of this? Need help I have to get my car up and running tonight. I also put RTV sealant when I put the pan back on. Any input on this should help me out some. Thanks
Old Aug 22, 2005
tuner04civic's Avatar
spell check pwns you
dont know if this will help but heres the prints for the oil pan...maybe u can see where 3 nuts go
http://www.hondaautomotiveparts.com/...+BLOCK-OIL+PAN
Old Aug 22, 2005
sweeteli99's Avatar
sweeteli99 will become famous soon enoughsweeteli99 will become famous soon enough
so you didn't put the 3 bolts where they should be? did you let the oilpan dry for about 24hrs in a warm area?
Old Aug 22, 2005
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Dude, just get the thing welded instead of using the bolts, thats what I did and NEVER had a problem .....
Old Aug 22, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
Are you talking about the 3 nuts that hold on the oil return line,, or 3 nuts that hold the oil pan to the block? If your talking about the oil return line, junk it, go buy a performance store buy earls fittings and have them welded onto the pan. Thats the only way your going to be forsure its not going to leak. Need anymore help message me on aol,---- webbiedx
Jeff
Old Aug 22, 2005
manahoonie's Avatar
?!?!? you can't figure out where 3 nuts go, but you say oil is leaking from where there's 3 studs w/o nuts...
Old Aug 22, 2005
cbaer543's Avatar
No you guys are misunderstanding me. I know that 3 nuts go on the studs I just lost the nuts that go to thoughs studs.
Old Aug 22, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Where is the oil leaking from, the return line where you had to drill through the oil pan, or where the nutless studs are?
If it is return line then you should get it welded or use some instant weld stuff atleast.
Old Aug 22, 2005
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
is this your problem?
Old Aug 22, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
The oil filter and pressure sender are right above the drain plug in the oil pan. Did you tap into the sender bung for oil feed or did you use an oil filter sandwich adapter? You are probably leaking oil from 1 of three places.
1) Where the oil pan meets the block from improper reinstallation of the oil pan.
2) The oil filter or sandwich adapter.
3) The oil pressure sender or oil feed fittings
Remember that any fittings that are not compression-style fittings must be sealed with teflon tape or paste.
Old Aug 22, 2005
civic01vtec's Avatar
did you let the RTV sit and dry for at least 1 day ????
Old Aug 22, 2005
blouisgod's Avatar
Life Begins > 6800rpms
werd - let that stuff dry and dont rush it.
btw - honda should start making actual gaskets like everyone else.
Old Aug 22, 2005
Drk01Civic's Avatar
I just realized you have an LX. The LX oil pan has a gasket. Did you put a new gasket on? Whenever I take the oil pan off and put it back on, I use a new gasket and Hondabond.
Old Aug 23, 2005
Jeff's Avatar
yes and make sure you torque it down in the proper order.
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 8, 2015 11:16 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
