oil feed line
Old Aug 19, 2005
SuperFrankie's Avatar
SuperFrankie should not be trusted
oil feed line
on a garrett t/3 super 60 what size should the feed line be 1/8th 1/4 what?
Old Aug 19, 2005
tfnaaf's Avatar
BLDNPSI Mod
guessing 1/8" pipe
Old Aug 19, 2005
i am assuming you mean id not od right?
Old Aug 19, 2005
tfnaaf's Avatar
BLDNPSI Mod
the approx OD on 1/8" pipe = 0.405"
Old Aug 19, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Pipes are measured on a goofy scale, they're by ID and then there's different schedules which is the thickness of the pipe wall. If you're dealing with NPT fittings and whatnot, then the holes are going to look a lot bigger than the pipe size that fits them. 1/8" NPT fittings are probably about 1/4" to 3/8" in diameter. Its all a game, then you have to translate that in the AN stuff for lines. -4 AN is probably the closest equivelant to 1/8 pipe. You could also use -3, but the -4 is bigger and I'd use that.
ZILLA
Jul 13, 2015 04:52 AM
Hqly2001
22
Jul 12, 2015 06:44 PM
1khilari
Jul 9, 2015 08:12 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
