Knock sensor and Emanage
Old Aug 11, 2005
HyaBoosta's Avatar
Since most of us have the emenage as our tunning control I had a quick thought. The emenage harness hooks up to all the ignition coils but not the knock sensor. Our knock sensor wiring is untouched. The knock sensor is supposed to retard timing when knock and detonation is heard automaticly. So with the emenage piggybacking and controlling the air and fuel. Would the stock knock sensor still retard timing if it detects knock? Then that would explain why some of us are running 10 and 12psi with nothing done to the ignition maps. Any thoughts?
Old Aug 11, 2005
civic01vtec's Avatar
Seems to me that you answered your own question.
Old Dec 6, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I did not want to start a new thread on the same topic.
But I think if there is a knock sensor to preven detonation, then detonation shouldnt be an issue (power loss may be, but no detonation) right???
Old Dec 6, 2005
turboengnr's Avatar
DONT PANIC
not really. the knock sensor will only retard timing and add fuel to a certain extent. Its parameters are defined by the ecu. Things like the AEM have a knock control option that can add a large amount of fuel and pull out a large amount of timing until the car stops detonating.
Old Dec 6, 2005
So stock ecu cant extinct detonation.
Old Dec 7, 2005
turboengnr's Avatar
DONT PANIC
it can only compensate for it slightly. There are no drastic changes in the timing or fuel curves.
Old Dec 7, 2005
andyman97's Avatar
Turbo Guru
Emanage ultimate has a knock sensor input.
Old Dec 7, 2005
HyaBoosta's Avatar
Emanage has the knock box that you can add into the knock sensor
Sep 26, 2023 06:44 PM
BootyDo
Jun 21, 2016 03:45 PM
15EXCoupe
Jul 30, 2015 12:59 PM
17
Jul 23, 2015 11:48 PM
mistermenphis22
Jul 13, 2015 04:43 PM
