Oil feed and return line
Old Aug 8, 2005
cbaer543's Avatar
cbaer543 is an unknown quantity at this point
I just wanted to see where other people put there oil feed line and there return line. That is the only problem I am having with the turbo install is where to put thoughs. If someone could give me an idea that would be great thanks.
Old Aug 8, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
There is oil pressure sensor just above oil filter, use that hole to run oil feed line. You will need to use T connection for it.
Oil return line, run a hose from the turbo to the oil pan. Tap oil pan on the side at the very top.
I hope it helps.
Good luck with your project!
Old Aug 8, 2005
2K1Civic17"Gabe's Avatar
perfect^^
I would recommend on the return line, connect it to the turbo, and see where it ends up on the oil pan. So you dont have any quinks(sp?) in it. You want a nice flowing line, and dont want to tap/install the pan only to find out you did it an inch or even less off.
Old Aug 8, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
heres another tip. use a short piece of flex hose with 1/8 npt ends (12"-18")for the begining of the feed line then tee it and zip tie the connection to some place cozy on the firewall. I have seen several hard connections break off the block from the engine vibrations. If it breaks and you arent paying attention say goodbye to Mr. Engine. You can get them from summit or jegs pre-made, you may hafta get like a NOS hose or an Autometer oil sending unit hose. The $10 is well worth the piece of mind.
Old Aug 8, 2005
tfnaaf's Avatar
BLDNPSI Mod
check your yellow pages for hydraulic supplies we have 2-3 places in town that can make any length/or supply stainless steel with fittings or crimped fittings to your length and fairly inexpspensive
RIPSAW
Nov 6, 2015 04:36 AM
Black91civic
Jun 6, 2015 08:15 AM
JoeB16
61
Oct 16, 2003 07:58 PM
drbombay
Feb 5, 2002 02:38 PM
FiresVTEC
Jan 21, 2002 02:34 PM
