What to do before puting turbo?
Old Aug 8, 2005
BlackFire's Avatar
BlackFire is an unknown quantity at this point
Well,
I'm about to make my car turbo and I have a question about what measurments should be taken to make sure that the engine's condition is appropiate to handle it:
First: The whole Short Block and head gasket have been replaced by Honda Dealership about 6 months ago because old block was blown (2 holes on cylinder wall on cyl #4 because of water going in from the CAI).
- Should I take off the valve cover and check the torque on the head bolts??
- They used a new head gasket, but I'm not sure if they used the 3 layer or the old one. Any recomendations?
- Should valve adjustment be checked too?
Don't know if any of this make sense to you, but I would like to know what should be checked on the engine before puting that turbo.
Thank you.
Old Aug 8, 2005
civic01vtec's Avatar
If Honda installed the HG, then the head should be to specs. If you are boosting, it may be a good idea to torque it to 3-4 lbs more than spec.
As far as the HG........OEM is fine.
How many miles are on your car??? If you know what you are doing, then you can check the valve lash.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
