Help me with my loose nuts...PLEASE!!!
Old Aug 3, 2005
Chompondis's Avatar
Chompondis is an unknown quantity at this point
I just installed my custom turbo kit about a 3 weeks ago. About a week ago I notice that the nuts that connect the downpipe to the turbo keeps coming loose. I would tighten it and a few days later it would loosen or pop off. the first incident actually was the one of the nuts that held the manifold on, that happened twice. after replacing one and tightening the other, the downpipe bolts started to loosen. I spoke to a few friend about it and everyone recommends to get a flexpipe and lock-tite all the bolts. Any help is appreciated. Do all you turboed people run a flexpipe? this every happen to anyone else? thanks in advance.
Old Aug 3, 2005
turboengnr's Avatar
DONT PANIC
use brass lock nuts. They work well.
Old Aug 3, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
Yes I would also recommend using a flex pipe.
Old Aug 3, 2005
dezod's Avatar
7thgen Power Maker
Flex is probably a good idea because the motor has been torqing & there is noting other than those bolts to absord it, so they are becomign loose.
Old Aug 4, 2005
Chompondis's Avatar
thanks fellas for the reply. ill try brass nuts and a flexpipe.
Old Aug 4, 2005
MiamiUgen7's Avatar
the flange may be warped as well causing it to pull away and loosen the bolts on there
Old Aug 4, 2005
HondaLuver's Avatar
Its a celebration bitches!
lets just think of a flex pipe as insurance
Old Aug 4, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
A flex pipe is necessary when boosting, the gyration of the turtbo and the torque of the motor's will cause your engine and turbo assembly to rock back and forward and slighty side to side as you accelerate and stop.
I'll say try the flex pipe, the brass bolts and lock tight (the red color) and see how that works.
If the bolts still come lose or brake, take the manifold and have it rectify at the flanges.
My manifold's flange connecting to the head was warped and caused the bolts to come lose after I fixed that I haven't had any problems.
Old Aug 4, 2005
andyman97's Avatar
Turbo Guru
Lock washers, urethane motor mount inserts. Make sure you're using the right torque specs for the manifold. I've never used a flex pipe and have no problems.
Old Aug 5, 2005
Chompondis's Avatar
thanks alot for the help guys, now i just have to find some time to do all that. All i gotta do is not skate for a day and all that should be done and done. thanks again for the replies.
GolNat
Nov 27, 2018 03:32 PM
Tyler93
Mar 20, 2016 09:03 PM
Joecrowe
Sep 24, 2015 09:12 AM
bashea
Sep 15, 2015 04:59 AM
MichaelLW
Sep 14, 2015 07:15 AM
