Axles
our axles can handle around 200hp 200tq it starts to get risky after that. lower that figure a bit if you are using slicks. Any axel shop should be able to hook you up.
I was about to start a thread like this, so instead, if i may, i will just add on.
I know that with a k20 swap the si axles are used, so how much hp can they handle??
Not sure about type s axles??
Also, how much horsepower can our 5 speed manual handle, with an upgraded clutch??
I donnot have any real mods, i just really am into this stuff, ever since a couple months ago when i read a book on turbos, i keep wanting more!!!!
I do plan on either swap or turbo, when i get $$$, and i figure i should keep rsearching and learning, knowlege is power.
I don't think the rsx and si will fit.
Our axles sux. I broke my at 8psi.
Abortion Survivor
haha k20 axles don't fit our transmissions ...
however, with a K series swap, any type of k20a3 axle will fit. k20a2/z1 axles are too big ... k20a axles are too big and too long.
you can get custom axles from driveshaftshop.com
I also figure out stock axles can handle about 200 hp or so.
"C2i0v0i1C" - has custom axles. PM him and see if he can get the ## of the shop.
I was trying to order a set when mine broke. But the shop he ordered, don't want to look it up the parts numbers. When I ask have they ever custom a set for 01 civic-up D17a engines? They said no.
driveshaftshop.com
435 for stage 3 300hp + axles..
http://www.7thgencivic.com/forums/sh...d.php?t=206909
proof they exist mine are in the shop being installed with my built TCI auto tranny
Sep 26, 2023 06:44 PM
beanhead
Sep 24, 2015 12:04 PM
califcamper
Jul 21, 2015 10:34 PM
