Which fuel pump
Old Jun 28, 2005
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
Which fuel pump
okay i'm trying to get another in-line pump...looking to get walbro...I found the site...which one to get...also if u know where I can find a better price, post it up also...thanx
In-line external pump I found online
Old Jun 28, 2005
HondaLuver's Avatar
Its a celebration bitches!
255...
Old Jun 28, 2005
JetBlu01's Avatar
New Member
which one off the site I posted below?
which pump?
Old Jun 28, 2005
andyman97's Avatar
Turbo Guru
call stan at www.fast-turbo.com and tell him you need the walbro 255lph. Best price I've seen.
Old Jun 28, 2005
Michalo187's Avatar
Abortion Survivor
I think slp also has them at a good price p m him
Old Jun 29, 2005
civic01vtec's Avatar
I got a MSD in-line pump from Jeff at SLP. It works great !!!!
Old Jun 29, 2005
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Hope you don't mind the thread hijak JetBlu01, I just had a couple questions related to the inline pump;
I understand the in line fuel pump goes between the tank and the fuel rail, do you still leave the factory pump functional or do you disable it?
If it remains enabled, does the in line pump add any stress to the factory pump which may cause it to fail in the short run?
Are there any cons at all to using an inline pump as oppose to modifying your factory fuel pump/fabricating an rsx fuel pump to work?
Thanks for humoring me.
Old Jun 29, 2005
stock in-tank pump stays fuctional.......the in-line pump is merely a booster pump.
Yes, it will cause stress on the stock in-tank pump. I have been boosted for well over 1 yr with this set-up and i am still on my stock in-tank pump at 56,000 miles.
They are loud and are not the best set-up for a fuel system. The best way, which is more expensive is larger injectors and a piggyback.
Old Jun 29, 2005
PrecisnTec's Avatar
gracias señor
Old Jun 29, 2005
andyman97's Avatar
Turbo Guru
I say go with the walbro. Only takes an hour or two and is very beneficial.
Old Jun 30, 2005
JetBlu01's Avatar
New Member
sweet thanx guys
liagreenhalgh92
Jul 21, 2015 01:31 PM
srtlat
Jul 17, 2015 11:53 PM
EliseKStewart
Jul 15, 2015 11:11 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
