Spark Plug Selection For Turbo
Old Jun 16, 2005
Sojsboy's Avatar
Sojsboy is an unknown quantity at this point
hey guys, turbocharged here, and i'm currently running the denso 5310. is this model good? cause i had a cylinder misfire code come up and i dunno if one of my plugs are gone or not, pulled them out and they all look fine, could it be my coils? should i buy the same pair of spark plugs or is there a colder plug that denso makes that you guys recommend? gonna switch my coils with a 01 civic lx later to see if that is the problem and reset the CEL. also going for compression test later to see if everything is ok, anyone have these problems? TIA.
Old Jun 16, 2005
Michalo187's Avatar
Abortion Survivor
Actually a couple of use have had this problem Get your car tuned that usually fixes everything check the gap. Try the coldest plugs and move your way up because the coldest ones might be too cold!
Old Jun 16, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
try iridium plugs. don't know if that would be too much but its a thought. the plugs are NKG
Old Jun 16, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
Try using a del sol vtec plug. The tuner yesterday told me to use those instead of the iridium plugs. Or Go one step colder than the iridium ik20 plugs. MAKE SURE TO CHECK THE GAP! I had cylinder misfire codes because of the gap.
Jeff
Old Jun 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
yup. ik20
kinda expensive though. $40 for 4.
Old Jun 16, 2005
200whp's Avatar
200whp is an unknown quantity at this point
^^^ Thats what i have they work fine
Old Jun 16, 2005
Sojsboy's Avatar
i have IK22, is that too big?
Old Jun 16, 2005
turboengnr's Avatar
DONT PANIC
get autolite AR-3934 or AR-3932
Those are 2 and 3 steps colder (respectively)
They are a copper race plug used very extensively buy the domestic race crowd. They work very well on the civics. Set the gap at .030" to .032" and you should have no problem.
Old Jun 16, 2005
turboengnr's Avatar
DONT PANIC
delete
Old Jun 17, 2005
Sojsboy's Avatar
is IK22 too cold? well i'm gonna order the ik20's and get them gapped to .32, is this a good idea or am i just wasting my time? also, gonna check my mechanic to check my injectors to see if their dirty, just stock ones right now, but got rsx injectors lined up, just waiting to be installed.
Old Jul 11, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Bringing from the dead, but:
I dont underdtand why regular factory specs plugs wont work with turbo.
http://www.densoiridium.com/find_par...&action=Search
follow the link, denso recomends IK20 for the stock 03 Civic. Is not it factory spec NGK that are in the car at the begining?
Factory NGK have spec at ZFR6F-11 with gap og .044 (NGK website)
So both sparks concider to be even, as far as application, where variation of slight persormance advantage on Denso due to technology involved.
So I think colder NGK ZFR4F should be fine for turbo where colder plug reqired.
Correct me if I'm wrong.
Old Jul 12, 2005
civic01vtec's Avatar
I am using Denso IK20's
BootyDo
Jun 21, 2016 03:45 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
stvpagn
Jul 9, 2015 09:59 PM
1khilari
Jul 9, 2015 08:12 PM
MamaBear2015
Jul 3, 2015 11:26 PM
