turbo break in?
Old Jun 1, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
turbo break in?
ok so if I drive the car hard, how long would I have to leave the car started before shutting it off, I was told 30 secs - 1 min, but someone told me 5 min and I was like
as of yet I have no turbo timer nor thinking about putting one in.
Old Jun 1, 2005
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
i leave mines at 1 min. hard driving would be about 1.5 min.
Old Jun 1, 2005
civic01vtec's Avatar
30 sec to 1 min is ideal. Anything over that will actually be worse cuz there is no cool air rushing into the engine cuz you are not driving. The hood will actually retain the heat of the engine bay. If i go on long trips i let it idle for about 2 min with the hood open.
btw........thread title has nothing to do with the topic
Old Jun 1, 2005
Michalo187's Avatar
Abortion Survivor
i do one minute all the time no matter what but i got a turbo timer
Old Jun 1, 2005
civic2k2's Avatar
civic2k2 is an unknown quantity at this point
Id say 30 sec to a minute would be ok, but if I was you I would definatly would get a turbo timer makes life so much easier, just turn the car off and let the timer do all the work.
Old Jun 1, 2005
bamb00's Avatar
damn turboed people!
Old Jun 1, 2005
im stock now! T.T
lol... I know I should get turbo timer but I dont want to bypass the car... dont you have to leave your key in the car too to bypass immobilizer?
I had remote start and had to leave key in the car then decided that remote start wasnt worth it so I took out my remote start.
Ive been driving my brand new turbo hella hard, hope that wont ruin anything. Its so hard to stay off boost.
Old Jun 1, 2005
civic2k2's Avatar
I know what you mean about boost being addictive. As far as bypassing the Immobilizer umm Im not sure being as I have a Subaru now. As far as mine went HKS made a plug n play harness for mine where I just snipped one wire so I could use my keyless to lock the car when I got out and once the timer finished the factory alarm would be active. Im not sure if they make a harness for the civics but you might try and go to a local performance place in your area and ask them if they could do it, which Im sure there is a way.
Old Jun 1, 2005
2K1Civic17"Gabe's Avatar
yeah, 30 sec-1 min is perfect. But like he said, If I drive more than an hour or two at a time, and its hot as hell in az anyways, than I let the car sit for a little longer with the hood open. If I am feeling a whole bumch of heat when i get out, I will open the hood as well just to take the heat off.
and agreed, the title had nothing to do with the topic. But I would wait at least a full tank of gas befoer stepping on it. It was easy for me, cuz I was too chickensh** at first to break anything.
you dont have to have your key in the car for a turbo timer. If the brake is up, the turbo timer stays on, but as soon as the ebrake goes down (with most or all turbo timers i think), than the car shuts off, even if you havent hit the set time for the timer. Thats the protection from it, so it wont start without a key and the ebrake down.
and drive nicely to get everything heated up, tighten it back down after a full tank of gas. Dont drive hard if you just installed it. Wait at least a tank of gas, than tighten everything back up, and boost away. thats what I did to be safe, you dont want to break your new setup already.
Old Jun 1, 2005
thats exactly what I want to do. I need my alarm to set after the car goes off. I hate waiting around for a minute in the heat to set the alarm. its abd enough not using my a/c in az, but waiting around after sucks even more. Any tips on how to do this?
Old Jun 1, 2005
civic2k2's Avatar
I dont really have a clue to be honest. I used the PNP harness and was told to snip the wire for it to work, if there was a turbo 7thgen in my town I could find out for you but theres none. Theres got to be a way to wire it up like mine, what TT are you using ?
Old Jun 1, 2005
I have the one that came with the TSI kit. Its just one of the functions of this little unit. You would have to see it, and work with it to figure it out. Its all good though, thanks anyways. I can live with it, but someday Ill figure it out.
Old Jun 1, 2005
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
sometimes when i get on the throttle hard and pull over and pop my hood and the exhaust side of the turbo and downpipe is glowing red. just to tell you hot i gets.
HondaGuy7
Feb 22, 2016 01:00 PM
Bikergofast
Sep 12, 2015 10:54 AM
