all turbo guru's
Old May 8, 2005
bigsamdog's Avatar
k!llin al-queda since 2002
bigsamdog is an unknown quantity at this point
all turbo guru's
i come in need of ur knowledge ol' wise ones j/k, but seriously i bought turboengnr's kit and i added a couple of things
Equal length manifold
garrett T3 Turbo
*new (never used) oil feed line
*new (never used) oil drain line
3" downpipe
vortec fmu w/ walbro fuel pump
Emanage w/ injector harness
Turbo XS RFL BOV
Intercooler piping (black)
3" air intake to the turbo
3" Filter
Couplers & clamps
MAP sensor check valve
intercooler 12"
Polished Aluminum Alcohol injection canister
Alcohol injection nozzle
Pressure switch
rsx-s injectors (still havent received from shadyimportracer)
greddy profec b-spec(waiting on stl01civic)
a/f gauge
boost guage
stuff i know i need:
return fuel line
other emanage harnesses
i wanna run 6-10psi daily,just wanna know what else i would need to run safely, gauges,hoses/line, anything else? besides internals thanx for the help
Old May 8, 2005
Havok2k1's Avatar
Wicked Pissah Admin
You don't need both the Vortech FMU and the E-Manage with RSX Injectors....
Old May 8, 2005
bigsamdog's Avatar
do they contradict eachother?
Old May 8, 2005
bigsamdog's Avatar
im learning as i go
Old May 8, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Its overkill
Old May 8, 2005
bigsamdog's Avatar
oh ok
Old May 8, 2005
turboengnr's Avatar
DONT PANIC
you could use the emanage to fine tune the fuel curve. Thats what i was using the split second unit for. If you want the software for the split second, i can send it to you.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
