Problems w/ E-Manage/Profec E-01 and car...
Old May 8, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
OK, The other day I was messing around with my e-Manage while the car was on, I went to the airflow adjustment map and I changed it but I never exported it to the e-Manage, but I don't know if this was the cause of the problem.
Now, the Profec dosen't display any of the features of the e-Manage such as Airflow output/Input, TPS ETC.
Now here's the weird thing the Profec is getting the TPS signal from the e-Manage cause you can check the throttle settings and it's getting it...but it's not showing up on the Profec anyone know why?
Then after that my car's idle started messing up, like it'll drive pretty gopod but the car is running way too rich, I can smell pure fuel from the exhaust, and the car sputters badly at idle and the exhaust sounds like I have cams...someone help!
Old May 8, 2005
coperandy731's Avatar
Sounds like a serial killer. Is that what you are?
coperandy731 will become famous soon enoughcoperandy731 will become famous soon enough
I ran into the exact same problem. I had to use a laptop to set the parameter settings instead of the e-01. Then send the settings from the e-manage to the e-01. Then you can use the e-01 to tune the maps selected in the parameter settings. Just don't change any of the parameter settings with the e-01. For some reason it messes things up changes the type of airflow sensor which causes the car to run extemely rich.
Use the support tool to set the parameters and check all maps needed. Then don't go back in parameter settings and you'll be good.
Old May 8, 2005
Hwoody77's Avatar
Is that why it nots communicating? So just go in and re-setup the e-Manage?
Old May 9, 2005
yes set it up again with the support tool and a laptop and you should be good. only use the e-01 to modify the maps
Old May 9, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
^^ Yeah, I had similar problems and using the support tool for the initial settings made everything all better.
CrewChief
Engine Swaps
Jan 10, 2006 11:04 PM
Michalo187
Oct 1, 2005 11:59 AM
LogicWavelength
Jun 17, 2005 01:53 PM
CivicMexicano
Engine Swaps
Mar 2, 2005 03:42 PM
xHoteKx
Mar 6, 2002 07:38 AM
