Do I need gasket?
A.K.A BlackCar --- Not From Califorina!
Do I need gasket?
do i need a gasket inbetween the turbo manifold and the turbo? i baught the kit used and it was already bolted on and its leaking there like a biach! and it sounds loud and NASTY.. BLOP BLOP BLOP BLOP.... the turbo spools up.. but its spooling around 3,000 rpm for right now (T25bb)... it should be around 2200-2300... do i needa gasket in there? or is there sumthin rong with the manifold?
you need all gaskets and if it is a used kit, i would have replaced them all.
Also, you need to replace your OEM exhaust manifold gasket
thaler4cuse
Sep 7, 2015 08:25 PM
Kyles24
Jul 12, 2015 09:15 PM
