ran 75 shot. intake manifold gone.
Originally Posted by civic01vtec
puddling
75 shot doenst blow the manifold, you were not using it correctly. you somehow closed the throttle plate and nitrous was still getting to th engine.
Broken Arm, How Am I Suppost To Shift
JUst curious????..what year civic do you have.....i mean..i have an 03 and I've Never EVER seen any Plastic Manafold......
Originally Posted by HeHateMe
Did you retard your timing 4 degrees? Zex states you have to retard 4 degrees if you use the 75 shot.
Originally Posted by Jrfish007
Yes, perhaps you might want to tell us how to do that without a full engine management control system. The ignition system is the coil type, i.e. no distributor cap to just twist.
you can't..... you need to be running and e-manage piggy back or a standalone ecu. My point was Did You Check Your Timing. If you don't have a way to adjust your timing, why go with the 75 shot?
maybe u guys can help.. heres tha update.
i replaced tha intake mani and tha map sensor.. but my car wont start up... i pulled a plug and lined it up to ground and there is no spark.. yes i checked tha fuses. what controls the spark since we have no distributor.. if its tha ECU does that mean my ecu is fried? thanks!
it might have been your microswitch mounting point. First couple bottle-fillups i did with 80-shot the whole time it worked fine, but one time where i shot it and the nitrous got messed up because the microswitch bracket broke off so the throttle got caught onto the bracket leaving me at wot while I was pressing the brakes. what i did was turn the ignition off immediately. that moment i thought my car was a gonner til i opened the hood and sae the bracket in half so i moved that and went on with my life.. i think somehow the microswitch was pressing meaning it was at wot when you werent even gassing it as much? there could be so many things that went wrong.
Also, have you reset the ECU, that will need to be done if you've changed stuff around.
2005seTO
Aug 30, 2015 10:32 PM
baconomics
Aug 26, 2015 07:47 AM
