ran 75 shot. intake manifold gone.
75 shot kills plastic intakes manifolds made by honda.. lol well many things went wrong but heres tha jist. i launched then gained traction. after that i shot tha 75 shot for 2 secs and everything blew up...
facts:
-intake manifold is done
-spark plugs are fine
-i ran tha 75 shot jets
-wet zex kit
-full bottle
-heater was on
-i have no upgraded ignition
-91 octane
-i have i.h.e
you peeps have any idea what went wrong and what i should do to get my car up and running again?
thanks!
here go pics of my intake manifold after 300ft down tha 1/4 mile
enjoy!
facts:
-wet zex kit
-full bottle
-heater was on
-91 octane
-i have i.h.e
thanks!
enjoy!
Ooooooo.... backfire = bad, you can get a metal manifold but, that won't solve the problem you have. You seem to say that you turned on the nitrous after you got traction, if so... stop that. But then you say you have the zex system, to my knowledge, the zex system won't turn on till 3rd gear above 3,000 RPMS, so how/why did you turn it on early?
Generally this happens because the fuel/air/nitrous going into the cylinder ignited before the intake valve closed thus pushing a mass amount of air out your intake while it was blowing up (think really bad here), this means you are engine was running extremely lean for these conditions (aka, you lucky this is all that blew up). To run this type of shot, you need one of two things, A/F controller, set it to about 13:1 or even 12.5:1 or choice number two and better choice IMO, use a higher octane, racing fuel or something along those lines.
To get your car running... well replace those parts, to use a 75 shot again, run higher octane fuel. If you simply get a metal manifold, you might blow the head gasket, this is designed to take the pressure away from the engine and release it in a manner that will cause less damage.
Nice pics by the way
tha zex kit shoots at wide open throttle... i mashed on tha gass and didnt go anywhere but 2 feet..
so if i replace tha manifold and my car starts up... i should be cool right?
thanks for tha info...
uh.... seems to me that you mashed it on high gear? Just because your at wide open, it doesnt mean your at wide open. The microswitch thinks its at wide open. I think you sprayed at high gear with the wrong rpms and mashed the gas so the microswitch will activate even though your at low rpm.
Where did you put the nozzles that spray the nitrous and fuel... maybe those were also mounted wrong.
oh and the nozzle is on my cai just below the sensor closer to the throttle body
you should mount your nozzles on plastic clamp that clamps the intake onto the throttle. I just put it right above the opening of the throttle. Next time, try mounting your nozzles there and not the intake.
I was wondring whos car that was on the flatbed. sux that happened bro. You need to upgrade your spark plugs. 2 ranges colder or buy zex plugs. the long narrow electrode on our stock plugs can heat up under n20 and act like a glow plug, stay hot, and ignite the air fuel before the valve is closes. On a 75 shot you should be running racing gas above 91 octane just to be safe. You cannot spray under 3500 rpm or you will puddle fuel and n20 in your intake mani. on a launch this can be difficult to do. you have to watch your tach and only got wot after 3500 rpm this is hard if you bog you motor on the launch and try to recover by smashing the gas. Sounds like the plugs where the culprit.
oh ya. nice looking car
MORE FUEL.
Get a return system with an FMU
Even a plastic intake will hold if more fuel went up into the mix at the right time.
I use to ran 100 shoot till my head gasket went but the intake was fine.
i had tha zex plugs.. i felt like my car didnt like them... my car would die out from time to time... right now im running tha ngk iridium ..
Yeah, your car is not going to like the Zex plugs, they're to cold for the engine to work normally, but they'll save your engine when you spray that big.
Because I mash the throttle too at launch,I have an automatic tranny
The zex plugs seem to work good on my car
AKA Mr. 60ft. Not to be confused with Civic_Redline
Just get a $100 window switch to prevent spraying at too low and high RPMs. $100 is better than buying a new intake and anything else that screws up. Just my 2cents. Oh and if your gonna run a 75 shot run 93oct or better.
Zex's manual says ONLY run 93 octane. Don't ever run anything less, I don't care what anyone tells you. The other thing you might want to look at is getting colder plugs directly from Honda. I know Ford offers plugs that are 1 step colder, I'd be willing to bet Honda can do the same.
The other thing I'd like to know is when you switch the bottle on. From the sounds of what happened I'd guess you weren't at high enough rpms and the nitrous / fuel detonated too close (or in) your intake manifold. Also I'd check that your injectors are okay, it's possible you melted something there as well.
Just as a reference point, I drive an 02 Focus with a vortech supercharger and run a 55 shot with it. I never spray with less than 105 octane and always after 3500 rpms. (usually after I shift into 2nd)
Honda is not going to give you colder spark plugs, because we don't really have a good backing like you Ford guys have (HFP is nowhere on par with SVT or Mopar or Nismo or Ralliart), so we usually go with new Denson IK20's (Insert plug for Dezod here). He can easily get colder plugs through them.
75 shot kills plastic intakes manifolds made by honda.. lol well many things went wrong but heres tha jist. i launched then gained traction. after that i shot tha 75 shot for 2 secs and everything blew up...you peeps have any idea what went wrong and what i should do to get my car up and running again?
thanks!
thanks!
Originally Posted by HeHateMe
Im also running a Zex wet kit on my 2004 civic. Zex states to mount the nozzle 6" to 18" from the throttle body. Is closer better
91 octane is good enough. Were not running no 100 shot here.
^^yeap puddling then ignition and BOOM... wheres that mustang vid where this happens, we should show him lol
Omg!!!
