for all yall turbo riders..=D
Old Apr 12, 2005
d17lpower03's Avatar
d17lpower03 is an unknown quantity at this point
wut fuel set up yall using to maintain your turbo??? fuel??? emanage??require alot of dyno tuning???...=D..i got a turbo kit for my em2...just wann aknow from the experts hehehe...thanks =D
Old Apr 12, 2005
tfnaaf's Avatar
BLDNPSI Mod
just a cut and paste from my other post on fuel system
Originally Posted by tfnaaf
for the ideal set-up....
Convert to walbro in tank fuel pump witha moddified fuel rail and pressure regualtor.
here is the return line going in to the tank...
picture of moddified fuel rail....
picture of pressure regualtor...
modified intank fuel pump assembly...
Old Apr 12, 2005
how much psi can handle on stock injectors????
Old Apr 13, 2005
aellerman's Avatar
aellerman is an unknown quantity at this point
1 or 2 maybe 3??
Old Apr 13, 2005
aellerman's Avatar
dude, use the search function... can't believe havok hasn't locked this stupid thread up.... this has been discussed like xxx,xxx times
SEARCH FOR IT!
Old Apr 13, 2005
TheSmuggler's Avatar
I'll be nice so you don't look for hours. You can run the kit on your stock fuel system, but not for long and not very high. Someone got about 4 psi before maxing out, but everyone's engine/injectors are differen't. I'd reccomend you spend 100 dollars and buy yourself a set of used RSX Type-S injectors. It will save you headaches. If your going to do a serious build of your engine, convert to the return fuel line (SLP carries them) so that you can safley run more boost efficiently. Yes, you should search... but I'll give you your answer this time.
IBTL
Old Apr 13, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
Ibtl
Old Apr 13, 2005
Havok2k1's Avatar
Wicked Pissah Admin
From the turbo FAQ:
Fuel System FAQ
http://www.7thgencivic.com/forums/sh...d.php?t=173609
Return Fuel Systems vs Other Forms of Fuel Manipulation
http://www.7thgencivic.com/forums/sh...d.php?t=196632
Return Fuel System Install info
http://www.7thgencivic.com/forums/sh...d.php?t=140975
RSX Injectors on a Civic
http://www.7thgencivic.com/forums/sh...d.php?t=161804
Ignition Timing and Electronic Fuel Manipulators
http://www.7thgencivic.com/forums/sh...d.php?t=171315
Smuggler already covered the basics so I won't post those.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
