Wastegate
Old Mar 29, 2005
cbaer543's Avatar
cbaer543 is an unknown quantity at this point
Wastegate
Could someone fill me in on the difference of internal and external? Just for a future high horsepower engine which would be the better why to go or is there really a difference? I guess thats the only parts of the turbo I don't know about really. Thanks
Old Mar 29, 2005
HyaBoosta's Avatar
If your looking for a high power build then I say you must go external. they can hold alot more pressure and less spiking.
Old Mar 29, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
external is a must for higher hp and looks way better too. external is a much better design and more reliable. the internal wastegate is ugly...lol
Old Mar 29, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
internal - is built onto the turbo
external - it has a flange on the manifold where you can mount the wg.
Old Mar 29, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I recommend the Tial 44mm wastegate.
Old Mar 29, 2005
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Tial 44mm, jesus christ we don't have 500 or 600 HP cars. You'll be good with a 35mm 0r 38mm from Tial
Old Mar 29, 2005
civic01vtec's Avatar
for a high hp motor, i suggest a different motor
Old Mar 29, 2005
I recommend it based on the fact that it is extremely easy to install and position.
Old Mar 30, 2005
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Just out of curiousity, at what PSI level is it generally recommended to use an external over an internal? IMO I think most people are just wasting their money on the external wastegates when turboing their D17s...
Old Mar 30, 2005
External is generally recommended over internal, not matter what boost level. Internal is acceptable till about 10psi (ish)
Old Mar 30, 2005
^^^Has it been dyno proven to provide better HP gains? I imagine if so, then it would be due to exhaust flow design characteristics. I dont know if I've ever read that anywhere, but I do believe that I have read that the internal wastegates work just fine within a certain boost margin which is the only reason why I would think people are wasting their money on externals if they are staying within the safe margin for an internal WG (stock internals and etc.) I'm still new at this so if I'm wrong, forgive me.
Old Mar 30, 2005
TheSmuggler's Avatar
Meh, internal is good enough when your running a 25/28 and arn't making like 300whp LOL. Remember not all of us are ballers. *looks at empty wallet* =*(
Old Mar 30, 2005
LOL thats also what I was thinking too so dont worry. You're not the only one, but actually I'm gonna run a t3 .42/.48 with an internal gate at 8 or 9 psi daily on stock internals. I think should be fine.
Old Mar 30, 2005
They make 3's with internal WG's? Damn, never seen one of those lol
Old Mar 30, 2005
^^^They're actually pretty common I believe.
Old Mar 30, 2005
Damn *Get's out from under his rock* lol
Old Mar 30, 2005
I would bet 90% of T3 based turbines are internally gated.
The reason an external makes more power is that the exhaust flow from the turbine isn't hit with the dump from the wastegate. This causes turbulance and therfore less hp.
This is general info for the type of internal that dumps into the same hole as the turbine. Some are seperated out and therefore perform better.
Old Mar 30, 2005
^^^That makes sense and its probably true to a certain degree though I've seen internally gated applications dyno just about as well as the externals in low boost set ups.
Old Apr 2, 2005
dannn's Avatar
unique conformist
dannn will become famous soon enough
this may sound moob but as long as we are on the topic of wg
is it possible to remove the wastegate off an internally gated turbo?
the reason i ask is that i bought a garrett t25 internally gated turbo off ebay and the seller couldnt give me more info on that
Old Apr 2, 2005
they sell plates that bolt on to the T3 turbos so that you can convert them to external but I dunno about the t25.
Old Apr 6, 2005
AV6 6MT's Avatar
AV6 6MT is an unknown quantity at this point
Regarding sizes needed for external wastegates. Tial makes a 35mm, a 38mm I believe now, a 40mm and a 44mm.
The MORE boost you are going to run, the smaller the wastegate you can get away with. For instance, an EVO running 22-24psi can run a 35mm wastegate no problem. However, if he wanted (hypothetically) to turn the boost down to 9psi (which he wouldnt do), he would need a bigger wastegate as the 35mm probably couldnt flow enough air.
Remember, the more boost you run, the SMALLER the wastegate can be, and vice versa, when running small boost, you need a bigger wastegate because you need to bypass much more exhaust (thus exiting through the wastegate).
If you see race cars thats run 40psi, and they have the 44mm external, its just because its the biggest baddest external made, they really dont need it. Ask anyone!
If I upgrade my turbo I will most likely get a 35 or 38mm Tial.
Boosted2k2
Feb 18, 2004 01:05 AM
Catalyst
Engine Swaps
45
Jan 30, 2004 12:52 AM
Boosted2k2
Engine Swaps
59
Sep 17, 2003 02:25 AM
Boosted2k2
Engine Swaps
20
Jun 16, 2003 01:05 PM
Voiceofid
Dec 6, 2002 08:06 PM
