D17 TSI Turbo Kits
Old Mar 11, 2005
  #31
SkyGuy86's Avatar
SkyGuy86 is an unknown quantity at this point
If we were running between 6 and 8 psi wouldnt we need to buy bigger fuel injectors than stock if we went with the GReddy Fuel option?
Old Mar 11, 2005
  #32
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Not right away, but I'd definitely recommend upgrading as soon as you can.
Old Mar 12, 2005
  #33
civic01vtec's Avatar
Originally Posted by HyaBoosta
I will personaly get on a plane, come to your door,make you pancakes
mmm.......that sounds good..........how bout a samwich too bitch
Old Mar 12, 2005
  #34
2K1Civic17"Gabe's Avatar
You all better do this upgrade, cuz you can not reliably run more than 5lbs without retarding ignition. TSI's "help" with timing, does not do a damn thing. It is hard to find somebody who will actually tune my car with the TSI unit, cuz I will basically blow my motor pretty quick. They say 5 psi is safe, so I got a greddy profec b (since TSIs boost controller Doesnt work) today for a 100 used from a friend. Emanage fixes that problem w/timing, as well as EMS (do they have one yet, its been covered like 128791827 times, but I forget) So you all better get Emanage with this, or you'll blow your motor pretty quick or spend another 800 getting all this.
TSIs unit is basically good for adding fuel and turbo timer, other than that, it isnt that great of a setup, IMO.
Oh, and dont think you wont reach over 6lbs, regardless of what everybody else says. I have hit 13psi and 11 psi with the controller set at 7. It is very very very very very possible to hit over 13 psi as well, considering I was at about 1/2 throttle, lol. It was definately a nice feel though, but do not rely in TSI's unit for very much. Its good to get you going w/out very many precautions.
SO BUY THE EMANAGE, and if you are relying on TSIs unit, I would consider upgrading ASAP, as I will be FOR SURE!!!!
The kit fit pretty bombly though. Fit sooo much nicer than I was expecting, only their electronics suck, especially considering the first unit only showed up half way, lol.
Old Mar 13, 2005
  #35
Daemones6's Avatar
Daemones6 is an unknown quantity at this point
I Just got a TSI Kit last week. I am thinking about getting the eManage right away to avoid all of the tune problems I keep hearing about with the TSI ICU. What else would I have to buy besides the eManage unit for it to integrate properly with the TSI kit?
Old Mar 13, 2005
  #36
Your Parts Guy
Ignition Harness
Injector Harness
Pressure Sensor
Pressure Sensor Harness
Old Mar 13, 2005
  #37
Daemones6's Avatar
Offering any discounts on the eManage package? I'm shopping around now.
Old Mar 13, 2005
  #38
Your Parts Guy
Check in the retail section here:
http://www.7thgencivic.com/forums/sh...d.php?t=190544
Old Mar 14, 2005
  #39
SkyGuy86's Avatar
Originally Posted by StreetLevelPerformance
The D17 kit doesnt include a FPR
It doesnt?
TSI Extreme Turbo Kit Includes:
- 1 Garrett Turbocharger with Internal Wastegate Set For 6 Pounds of Boost
- 1 High Nickel Composite Cast Exhaust Manifold
- 1 Downpipe with Gasket
- 1Fuel Pressure Regulator
- 1 Map Unit (Black Box)
- 1 Stainless Steel Braided Oil Return Line and Fitting
- 1 Air Filter with Piping
- 1 Injection Control Unit with Turbo Timer
- 1 Injector Interface Block with 2 Injectors
- 1 Blow Off Valve
- 1 High Flow Intercooler with mounting hardware, Pressure Tubes, Rubber Hose Connections and Clamps
Old Mar 14, 2005
  #40
Your Parts Guy
It doesnt?
- 1 Blow Off Valve
All other TSI kits include the FPR. The D17 kit doesnt include it because you can't use it without converting to a return style fuel system.
Old Mar 14, 2005
  #41
SkyGuy86's Avatar
It doesnt?
- 1 Fuel Pressure Regulator
- 1 Blow Off Valve
Old Mar 14, 2005
  #42
SkyGuy86's Avatar
Ahhh I c said the blind man
Old Mar 14, 2005
  #43
SkyGuy86's Avatar
sorry bout posting that twice
Old Mar 14, 2005
  #44
SkyGuy86's Avatar
Dose SLP have RSX Injectors that we could buy? Or should we just get some from our dealer?
Old Mar 14, 2005
  #45
HyaBoosta's Avatar
^if youcould get new ones thats a good bet but if not then theres always a set floating around on clubrsx.
edit: heres someone selling a set RSX-S injectors
Old Mar 14, 2005
  #46
Is the pressure harness for the emanage for controlling boost, oil pressure, whats up?? Just curious. I will start out with the emanage w/timing harness and buy a few more. I can get tuned to 8 psi if I can control the ignition. In 120 degree summers, you can say bye bye to my motor anything over 5 lbs. Im hoping Ill be ok running 5psi tuned, w/out retarding timing. Ill get retuned in a couple months when its about 105 out.
Old Mar 14, 2005
  #47
AzNmiKex215's Avatar
2k1civic.com O. G.
Have all the manifold fitment issues been totally cleared? I read that it was in another post, but i just want to be extra sure.
Does it come complete with all fittings, hoses, clamps etc?
Honestly, how would you compare it to dezods kit?
Old Mar 14, 2005
  #48
Your Parts Guy
Pressure sensor is used to tune for boost. The pressure harness is used to connect the sensor to the e-Manage.
Old Mar 14, 2005
  #49
Your Parts Guy
I believe if you want to retain A/C you have to shave the manifold a bit. It does come complete with all fittings, hoses, and clamps.
I haven't seen any 5 speed numbers with Dezod's kit so I can't compare performance. I do know that a few people are in the 13's with the TSI kit.
Old Mar 15, 2005
  #50
dinglenuts's Avatar
dinglenuts is an unknown quantity at this point
its really tough to get an idea for a comparison with no dynos up yet, but based on cost comparison, with the new fuel options, I'm leaning a bit this way now
Old Mar 15, 2005
  #51
You will have to shave the manifold slightly. A dremel works just fine for it. A grinder would be much faster though. You do keep A/C with the TSI kit as well. Its a pretty good kit, just order the emanage instead of using TSIs unit. its ok for fuel, but does nothing for timing, regardless of what their directions say. They say it adds more fuel to eliminate preignition. It doesnt do that, they try to make you feel comfortable using the unit. It is no more than a vafcII w/a turbo timer. but still a nice kit, I am very happy, as you would be. Just do the deal from Streetlevelperformance w/the emanage for a 100 more
Old Mar 15, 2005
  #52
Your Parts Guy
Well put!
Old Mar 15, 2005
  #53
oh, and I dont think the manifold will go on w/out shaving it. It wasnt the A/C that was in the way. They shaved part of the manifold for ya, I just have no idea why they shaved it where they did, lol. It fits fine where it was shaved at, just the top right side (drivers side) needs to be shaved, when you try to install it, you will see what spots blocking it, only like a 1/10 or 1/8" needs to be shaven, nothing that will damage anything at all. its such a heavy/thick manifold. wont bust up on ya.
other fitment issues, were one pipe by the drivers side wheel. best bet is to have one of the pipes custom made. I used a flexitube that we got from the store the last night of install. So I just bend it to where I need it (basically straight, their pipe was bent in the middle) Your best bet is to get a custom pipe though, considering your right hand turns will be VERY wide. lol if I turn right it hits the pipe. well only on sharp turns, but its very driveable like that, not tooooooooo bad. everything else is fine, just takes some messing with to figure out how it all goes together. All the issues other people had, should be all fixed, or they installed wrong. JMO, not a bad install, have a few days (weekend) and a few smart friends helping you so you just work through any difficulties that much quicker. We were up til 6 in the morning a couple days in a row, and the last morning (sunday) we got to fire it up around 4:00 am. Woke up all the neighbors, especially since I had no exhaust. I had to hacksaw it off, cuz the shop that put it on, welded it all together. Stock exhaust should bolt up fine.
Oh, and the B-Pipe will rattle against the sway bar, you could get that remade/bent for cheap as hell.
Get the kit though, you'll be happy.
Old Mar 17, 2005
  #54
Your Parts Guy
The video and new instructions should help eliminate installation errors.
Old Mar 17, 2005
  #55
dont forget a clutch as well people. I will have money monday, tuesday at the latest next week, but I also need possibly a stage 3 clutch. Stage 2 would probably work, but 3 would be better. The wastegate doesnt work right, or is open too much. I hit 13 lbs under 4,000 rpms, at not WOT. I need to figure this out, and apparently my profec-b wont keep the boost below what the wastegate is set at. I thought it would lower boost if wanted, not just raise. I am having some issues, but these are normal turbo issues, not TSI issues. Their kit went on nicely compared to everything Ive been freakin out about. I didnt worry about anything on their kit, since from looking at it, you can tell it will be a nice fit.
They were tuning my car today, and it slipped like hell over 5000 rpms. They got me a 12:1 a/f ratio, and didnt charge for it. So I am set for under 5 or 6 lbs for now. Pretty sweet. Ill give them all my business, since the first shop gave me the finger, and set they dont tune today when I set it up for today, and even went down and talked to them, and saw my name for thursday. I went to SRD (superior racing development) and they are the chillest people compared to the others. Nice, smart, and helpful, and free today
Clutch still the same price for stage 3, or whats that run, also pricing on Stage 2, Thanks a lot, let me know
edit - my dumbness
Old Mar 17, 2005
  #56
Your Parts Guy
edit - my dumbness
Exedy doesnt make a "stage 3" clutch for the D17. Neither does ACT for that matter. The ACT Xtreme pressure plate or the Exedy Cerametallic is all you'll need. Exedy is cheaper than ACT. Stage 2 clutches are going to be more expensive than stage 1 clutches no matter what brand you choose.
Old Mar 17, 2005
  #57
I figured that much. How much is the ACT and how much is the Exedy, the ones you mentioned^^
Old Mar 18, 2005
  #58
Your Parts Guy
PM'd you bud
Old Mar 19, 2005
  #59
Daemones6's Avatar
Any new on the new install instructions and video? I'm going to the shop today to have the guy look at it. New instructions would help before he installs and tunes it.
Old Mar 19, 2005
  #60
Your Parts Guy
Nothing yet.
