AEM EMS feedback any one?
Old Mar 1, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Post here if you do.
Me like many others are curious to see the first impresions and numbers of this system.
Also I'll like to know what the overall costof the unit and all harnesses and sensors needed for boosted engines.
And the cost associated with the install.
Old Mar 1, 2005
dezod's Avatar
7thgen Power Maker
I have feedback on with other vehicles.....not the D17.
Well worth it. Tons of ability to modify settings. Install is cake, plug and play not like the E-Manage. Depends upon how indepth you want to go, the cost plays more of a role.
Old Mar 1, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I also have expirence with other applications. However the software is fairly similar for all applications.
Old Mar 1, 2005
opto_isolator's Avatar
Its supposed to be plug and play. The only bad thing is - you are going to need a lot of expensive tuning to get it set right....
Old Mar 1, 2005
civicskater's Avatar
Chicks dig my scent
and a lot of $$....should be worth it on the D17. If i knew what I were doing in the next 6 months with my car i would probably start saving to buy it. But not sure, someone will, and someone will make 300+ numbers
Old Mar 1, 2005
supermex's Avatar
I do apreciate the feed back but, I realy want to know how will it work in our cars.
We know that a lot of products that work on other cars don't do as well with 7thgens
I know that an A/C switch has to be installed.
How much and how hard is to install and, better yet, does it work?
I know that different settings would have to be installed when boosting.,
Would we need a boost sensor?
I want to hear from ppl that actualy have it installed and tunned.
Old Mar 2, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
You just buy the aem 3.5 bar map sensor and recalibrate the maps for boost. I just got mine today. I havent installed it because my motor is apart. With the map sensor it was around $1650. I have access to a dyno for cheap money. All I can say is wow. Its relatively easy to configure with the basemaps. A little more complex than the emanage. There are so so so many options. Traction control, two step and rev limits by fuel and ignition cut, shift cut, boost controller with the $45 soleniod and so much more. Its not for the inexperienced though. If you dont understand manifold pressure and injector pulse width dont even open the cal maps. I dont have ac so I cant tell you if it works for sure. This is totally sick and the best part is if I ever wanted to boost a k20 I dont need another standalone ecu.
carid
Nov 7, 2015 01:46 AM
kevfarr
Sep 18, 2015 02:28 PM
naokigoffi
Aug 30, 2015 06:19 PM
spyder13
Jul 31, 2015 06:31 PM
Theshwartz35
Jul 17, 2015 11:13 PM
